Grille installation question
Hey forum,
So I noticed that the way the old grille was connected to the brackets was via rivets, is this necessary when I install new brackets? Or can I just bolt and nut it? |
Re: Grille installation question
![]() Join Date: Jul 2016
I use these
http://www.althafastener.com/67-68-6...nut_p_173.html Your grill was not originally installed with pop rivets, it had hard rivets similar to the bolts I posted. |
#4 | |
How many are needed for an install? just prepping for the work ahead on my 1969 C10
Hey Mantruck, I believe it’s 12. I got 15 just in case.
Someone put screws with nuts on my truck. They were old straight head screws and were rusted so bad I had to drill them out. Use stainless if you are going to screw them in. You can only see the 4 in the front without opening the hood and the screws look fine. I picked them up at the local auto fastener store.
Stupidity was meant to be painful! |
| Bookmarks |
