Old 12-17-2018, 02:04 PM   #1
thegrandiman
thegrandiman's Avatar
How to C-Notch Video
Guys,
First time installing air ride. I've been documenting the steps up onto this point. Our 68 CST is a Father Son project and my 6 year old is loving it.
Here's a video of how I did the C Notch. Thought it might help someone out. Subscribe if you want to see upcoming videos.
https://youtu.be/jO0ZFS5dcVY
*Question - in the video you'll notice that i have 2" drop blocks installed. They allowed the axle to bottom out in the notch. I have since removed them to help with my pinion angle but I have about 2" before that axle will bottom out in the notch now....What are you guys doing to get maximum drop and have a decent pinion angle at ride height? Do they make Shimmed drop blocks?
Thanks.
Matt Grandi - 1968 CST C10 LWB.
thegrandiman is offline   Reply With Quote
Old 12-17-2018, 02:45 PM   #2
Zeroman
Zeroman's Avatar
Re: How to C-Notch Video
I would post this in the Suspension Board on this site.
Probably get a quicker answer.
Zeroman is offline   Reply With Quote
Old 12-17-2018, 04:39 PM   #3
Swar
Swar's Avatar
I've done this exact mod and in my experience, there's really no solution other than using the 2 inch blocks because the bags need room between the trailing arm and frame to work properly. Otherwise, the bags will squash before it bottoms out on the bump stops. You could just add a big washer on one side of the U bolt between the block and trailing arm if you need to change the pinion angle. I didn't notice any change on mine, though.
Swar is offline   Reply With Quote
Old 12-17-2018, 06:53 PM   #4
thegrandiman
Ok. Cool. Do you have any pics of your ride? Just curious, what do you have done to the front. I'm doing bags, cupping the lower control arms, and 2" drop spindles.
Old 12-18-2018, 10:00 AM   #5
Swar
Swar's Avatar
Here's a thread I made back when I was learning as I went.
http://67-72chevytrucks.com/vboard/s...d.php?t=651651
Last year I cut the back half of the frame off and welded up a new one to slam it. I have Choppin' Block control arms and 2.5" drop spindles. Cupping the LCAs and drop spindles will make it go much lower in the front than your rear setup. Your ride height will probably have a slight rake.
Old 12-19-2018, 07:16 PM   #6
thegrandiman
Awesome. Thanks for sharing!
