Converter recommended for c3500hd
I’m swapping my 01 c3500hd from the turd 6.5 td to a ls 6.0. I’m planning on using the stock 4l80 in the truck. Being an 01 it will bolt right up. I need to buy a high stall converter. I’m not sure if I should buy an ac Delco stock converter for a one ton truck or go to the aftermarket b&m,tci etc. the gvw is 15000 and I believe it runs a Dana 80 (need to check the ratio), 19.5” wheels.
This is a work truck that frequently carries a load. Any recommendations?
87 k5 silverado 4x4 350 38k stock 77 k5 Cheyenne 2wd 5.3 4l60e project |
| Bookmarks |
