Wire clips and hangers
What is everyone using for supporting the wire loom under the dash and engine compartment?
I am looking at those self adhesive pads that you run a zip tie through , do they hold up ? |
![]() Join Date: Dec 2009
Re: Wire clips and hangers
GMC Paul is a vendor on this site
If you look on his site and search for: 1967-72 Wire Harness Gutter Plastic Channel Used To Route Wires Across Firewall or Radiator Support Hope this helps
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
The plastic stick-on clips/wire holders are one of those things that you get ehat you pay for. Most any clip that has "3M" sickty tape should be of better quality. I have seem the cheaper one's plastic get brittle, but mostly due to outdoor applications. I have also seen the cheaper one's sticky tape get dry and let go, then you have the wires unsupported with a square piece of plastic zip tied to it.
I will typically find a place to zip tie the wire bundles to and avoid adding sticky hangers where possible. That covers most cases unless you are OCD, then I can appreciate the "neatness" of the hangers. Look for the 3M stuff. I would avoid them in the engine bay really. The environment will be hard on the palstic and tape both. Under the dash is a better place for them to live.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
| Bookmarks |
