![]() Join Date: Nov 2018
Glove compartment installation question
Does the glove box cardboard go inside or outside the dash frame? In the picture, is this right or wrong?
The joys of having things you didn't take apart yourself...
1970 C10 LWB Stepside 1971 Dodge Dart 1993 Buick Roadmaster Estate Wagon |
#2 | |
The Older Generation
Re: Glove compartment installation question
LockDoc
![]() Join Date: Aug 2014
All the inserts I’ve done I put them under the dash with the hinge on top of the grill and the screws would go through the hinge then the dash and last into the glove box insert. You shouldn’t see the edge of the insert at all. That’s my two cents.
#4 | |
I think it would look cleaner the way you're describing.
Some of the inserts have the same type fastener you’ve described on the side holes also at the bottom holes.
Ive also seen others that supply you with clip type fasteners that you put over the cardboard insert and you line up with the screw holes. Ive also seen them with the little flat clips that that have the sharp corner point’s to press into the cardboarded inserts for the screws. They should have been in the same baggy that the screws came in. But if you dont have them you can easil purchase them at the hardware store. |
![]() Join Date: Oct 2010
On another note, what color is that interior?
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
Medium bronze (paint code 522).
| Bookmarks |
