Old 02-07-2019, 02:31 PM   #1
kens65fb
Ram Horns ??
When I acquired my 64, it had a set of crappy rusted headers already installed, they look bad, and they hang pretty low.
I want to replace them.
I have found, that I can get a set of cast iron aftermarket ram horn style manifolds, for a comparable price.
I have a mild 350 4 BBL, that I'm happy with, no need for high performance.
Also the cast manifolds should eliminate any clearance problems as well.
Does anyone make a transition pipe to get from the ram horn manifolds , down under the truck ?
Any comments or suggestions??
https://www.summitracing.com/parts/sum-g9200n/overview/
kens65fb is offline   Reply With Quote
Old 02-07-2019, 03:43 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Ram Horns ??
These have been known to work and come with the flanges, just cut as short as needed tack weld for fit and weld out when your happy:
https://www.speedwaymotors.com/Tight...teel,1722.html
I don't know if these pre made units will fit the cross-member - https://pypesexhaust.com/i-12200745-...rn-dcc10s.html
