02-19-2019, 08:44 PM | #1 |
Hood ornament tech
What in the hell is the application difference between these hood ornaments?
They are 1981 only 5.7 diesel. Part numbers under are the same as just the run of the mill hood ornament. I cant find any documents on them specifically. Secondly, the yellow one has a busted stud so I need to swap it to the other one. How can I do this without hurting myself? lol Or suggestions for repair on the yellow one. Thanks
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2 1991 V3500 350/4l80/205 60/14 4.10 35 toyos. Last edited by obijuan; 02-23-2019 at 10:40 AM. |
02-20-2019, 11:55 PM | #2 |
Re: Hood ornament tech
Yellow is for Chevrolet and Red is for GMC. Push spring a little past hook part of hood ornament and tape ends together. The spring should slide off and to put back together do the opposite. Push spring down as far as you can and hook with one side of it. Cut the tape and slowly twist spring till it is at the top of spring
79 Chevy 2wd BIG10 350 TH400 |
