Old 02-25-2019, 07:31 PM   #1
pimpston65
pimpston65's Avatar
why the difference
found these two why did they make 2 and which came first.
pimpston65 is offline   Reply With Quote
Old 02-25-2019, 08:32 PM   #2
350TacoZilla
Re: why the difference
From what I've been told the solid one was the 1st design and they went with the multi-piece one to help dampen vibrations through the shifter and give it a bit of a buffer from people being too forceful with shifts and munching gears.
350TacoZilla is offline   Reply With Quote
Old 02-25-2019, 09:27 PM   #3
pimpston65
pimpston65's Avatar
ok. i was thinking they had a casting defect and this how they solved it in house...
Old 02-25-2019, 09:38 PM   #4
Short 3/4
Great timing on this question, I was just wondering the same thing. Are both of these styles correct for the SM420? Anybody know if the change was made by date or application (C10 vs C30 or K vs C truck etc).
Any chance of a picture showing the entire sticks side by side?
Thanks for info
Tom
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 02-25-2019, 09:50 PM   #5
pimpston65
pimpston65's Avatar
Thanks for info
Tom
i dont have history, but i could post them side by side.
Old 02-26-2019, 06:44 AM   #6
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Seems to be something going on for 1965.
Old 02-26-2019, 06:54 AM   #7
aerotruk63
aerotruk63's Avatar
Took a picture course it doesn't load. Parts Book states first jobs 1 piece construction less sleeve. After jobs welded construction with sleeve.
part number 3665527 60-62.
3822568 63-64
Same part number as 63-64 for first jobs 65
3860941 65 After Jobs
There are illustrations for a 60-62 4spd transmission and also 63-66. So there must be a difference as well between the two.
Old 02-26-2019, 11:23 AM   #8
Keith Seymore
Keith Seymore's Avatar
There is actually another later version during the square body era.
The sleeve version shown here has a square feature that fits in the base with rubber molded between the two. A later version is round internally and has 2 “O” rings to provide the isolation.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-27-2019, 01:55 AM   #9
Short 3/4
Yes,
More pictures by you or anybody else would be great,
292-SM420-T221
Old 02-27-2019, 07:22 AM   #10
pimpston65
pimpston65's Avatar
Yes,
here u go
Old 02-27-2019, 07:23 AM   #11
pimpston65
pimpston65's Avatar
here u go
yes one is shorter then the other maybe by a 1/4"
Old 03-11-2019, 10:50 PM   #12
Short 3/4
I'm trying to figure out what I have in my pile 'o parts.
My two solid sticks are identical, but the multi-piece one is thicker and about 6" shorter, plus the bend is closer to the base. Would this be correct for a 65?
Are the transmission towers different depending on which stick it came with, or are they all interchangeable?
Finally has anybody replaced the rubber within the lower end? Factory manual refers to them as 'Polyurethane "O" rings'. Where would you get the correct part?
Thanks,
Tom
292-SM420-T221
Old 03-12-2019, 12:59 AM   #13
pimpston65
pimpston65's Avatar
Thanks,
Tom
i swapped mine without any fitment issues, i have an extra donut ring that sites between trans and floorboard, if thats the O ring ur taling bout.
Old 03-12-2019, 02:39 AM   #14
350TacoZilla
Thanks,
Tom
Its always hard to say without seeing the parts but from what I've seen and read here then yes the multi piece one should be for 65-66. The bend & length being different would make me wonder if it wasn't out of something odd like the old c50 bus's or something. Maybe post up a pic or 2 comparing them. I'm also not sure if the factory ones are supposed to be interchangeable but I know a ton of square body guys change out the multi piece ones for solid ones or weld them up tight due to them getting loose repeatedly. I personally bought a brand new solid one just to avoid all that when I was hunting for parts and kept finding sloppy shifters.
Novak sells the solid one and says this as title "Stick, shifter cane, SM420 & SM465 transmissions, upgraded one-piece version"
