Old 03-20-2019, 12:26 PM   #1
Shtudwn
Replace 76 a/c cab with 76 non-a/c cab?
Hello,
I have a rusty 76 K20 that has a/c. I have found a 76 K20 non-a/c cab for $100.
Are there any concerns with changing cabs?
I notice that there is no cargo light in the donor cab but other than that nothing else jumps out at me. Both are auto trans. I know that I will have hoops to jump through in swapping VIN numbers. Anyone ever swapped cabs in Washington State?
Thank you.
Shtudwn is offline   Reply With Quote
Old 03-20-2019, 12:29 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Replace 76 a/c cab with 76 non-a/c cab?
You have to have a title usually for both cabs to switch.
Warrens69GMC is online now   Reply With Quote
Old 03-20-2019, 12:41 PM   #3
Shtudwn
Thank you.
Yes, I will be getting the title with the donor cab.
Old 03-20-2019, 01:28 PM   #4
Dead Parrot
Double check the differences between AC and non-AC electrical. The climate controls for the heat only cab may be cable vs vacuum for the AC cab. Might not need the vacuum pot on the firewall.
Dead Parrot is offline   Reply With Quote
Old 03-20-2019, 06:07 PM   #5
95 S_Trucker
95 S_Trucker's Avatar
The firewalls are different where the hvac box mounts. Be prepared to lose your a/c. Or you can cut/fill holes if you want to keep a/c. I have pics in my 78 build thread where I put a/c in a non a/c cab.
95 S_Trucker is offline   Reply With Quote
Old 03-21-2019, 02:16 PM   #6
75C10
Adding factory AC to a non AC cab is simple. I have done this several times.Use the under hood AC unit as a template and draw out cardboard then use this to add subtract to the firewall. Not difficult.
75C10 is offline   Reply With Quote
