fuse block and relay for harness ?source
I know you can build your own fuse block with relays to go on a stand alone wiring harness but are they available to buy already built?
Re: fuse block and relay for harness ?source
Second that. I used him to flash PCM and his videos to and pin charts to clean up my harness. No issues!
![]() Join Date: Aug 2018
I don't know of a source for a pre-built fuse block. What I bought is a weatherproof fuse block/relay block on Amazon: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The fuse block that Brendan at LT1Swap uses has bussed terminals, but the one I got doesn't unfortunately. I went with the one from Amazon as it's a wateproof enclosure and has a lot more space and is a complete unit. I'll be using two standalone buss bars with my setup so I don't have to struggle with crimping more than 1 wire onto each terminal at the fuses and relays. One for grounds and one for power.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
Like this? http://www.currentperformance.com/sh...erelay-module/ It's kind of a $125 solution to a $30 problem, but they do look nice.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
![]() Join Date: Jan 2018
BP Automotive also makes what appears to be the same fuse block as the one LS1Nova added. I got their harness and am happy with the quality but it is not installed yet.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
![]() Join Date: Jun 2012
For the relays i mount under the hood i used these from Racetronics. They are good quality sealed weatherpak.
https://www.racetronix.biz/product.asp?ic=rycs-001 For the fuse block i mounted under the dash i used this one. https://www.racetronix.biz/product.asp?ic=fbk-001 And for a junction box i used this. https://www.racetronix.biz/storeitems.asp?cc=junct-00
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
