97 ABS problems
The ABS on my 97 K1500 has been engaging at low speeds like when I pull up to a stop sign so I pulled the 60a fuse under the hood. Recently I got an Autel MaxiDiag Elite scanner that is supposed to read ABS codes. The scanner works great on my wife's 05 Impala. When hooked up to the Silverado the ABS system doesn't even come up on the scanner menu. On the Autel forum I've been told that the problem is that's what happens when the module isn't powered up, is defective or has a com problem.
Any ideas on how to test the module or if perhaps the ABS isn't supported on the Autel MaxiDiag? Thanks Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
| Bookmarks |
