Old 04-24-2019, 11:18 PM   #1
LuckyRabbit4
Where to start?
So I have a 1966 c10 pickup longbed stepside with a L6 250(I believe).
Looking to start restoring asap. But not sure where to start.
I plan to rebuild the engine and USE the truck as an actual truck as I continue to upgrade and mod it to the point of just pleasure.
What I need to know is the basics. What should I do first, after engine? Runs now just blown head gasket. Brakes? Suspension? Clean and restore all rubber bushings? new bearings? I want to make this safe all around but I have to go step by step. Truck is legit all original 1966 except a new 3 row radiator I installed when I bought the truck.
LuckyRabbit4 is offline   Reply With Quote
Old 04-24-2019, 11:31 PM   #2
Captainfab
60-66 Nut
Re: Where to start?
After getting the engine running, I would say that brakes should be next on the list and then steering. All safety items first and then nonessential things can be addressed.
Old 04-24-2019, 11:36 PM   #3
LuckyRabbit4
Re: Where to start?
Would you do suspension (bags or lowered) at the same same time? Or individual upgrade? Ideally caliper conversion for front and back I'm sure.
Old 04-25-2019, 02:00 AM   #4
Bushman66
Re: Where to start?
Exactly the order I am following with my 66. Keeping it stock for now, will sort out upgrades (PS, A/C, and Power Disc brakes) and cosmetic issues later. Working on the long neglected cooling system with a new OER 4 core radiator on order from Classic Industries (the 292 runs currently), then a complete 4 wheel drum brake overhaul, fluid changes and tires.
Bushman66 is offline   Reply With Quote
Old 04-25-2019, 11:36 PM   #5
Captainfab
60-66 Nut
Re: Where to start?
No. I would get the truck running and driving safely first. Then decide on what you want to do next. Trying to do too much all at once can easily become overwhelming, which often times leads to selling the project dirt cheap just to make it go away.
Old 04-26-2019, 05:47 AM   #6
aerotruk63
aerotruk63's Avatar
Re: Where to start?
Follow the Captains orders...he's right unless you have the extra cash on hand.
Old 04-26-2019, 09:07 AM   #7
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Where to start?
Enjoy it while you build it, like the Captn says! This forum has seen many folks with good intentions just loose interest because life gets in the way of plans! Get it running, stopping and safe, drive it while you collect upgrade parts...you will be glad you did!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-26-2019, 12:49 PM   #8
sirJim
Re: Where to start?
I try to gather all the parts for a reasonable day or weekend projekt then choose the day or weekend and keep it in drivning condition.
http://67-72chevytrucks.com/vboard/s...d.php?t=737695
62 burb in the making.
sirJim is offline   Reply With Quote
Old 04-26-2019, 06:02 PM   #9
demian5
demian5's Avatar
Re: Where to start?
Ive been going through a 1960 Apache. Ask away.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 05-01-2019, 10:16 PM   #10
LuckyRabbit4
Re: Where to start?
Looking forward to getting this going asap. Thanks for the help! I can't wait to be able to drive her around again. Sat all winter 😔😔
Old 05-03-2019, 11:17 AM   #11
demian5
demian5's Avatar
Re: Where to start?
GSST
Go, Stop, Shift, turn
1986 C20 Scottsdale
Instagram: C10sofOC
Old 05-03-2019, 12:13 PM   #12
roll_the_dice
roll_the_dice's Avatar
Re: Where to start?
Truer words have not been spoken! This is my first attempt at redoing a vehicle and it is daunting if I look at the big picture...but if I take one piece at a time, it can be done. Take pictures and document everything you do so you can remember how something goes back together. I am trying not to do 5 projects on the truck at once, but one then another....slow and steady wins the race. Good luck..and you won't find a group of better people than the enthusiasts on this board!
roll_the_dice is offline   Reply With Quote
Old 05-03-2019, 12:19 PM   #13
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Where to start?
... which often times leads to selling the project dirt cheap just to make it go away.
Yep, that's how I bought mine.
Old 05-03-2019, 09:54 PM   #14
Wrenchbender Ret
Re: Where to start?
For dependability go through the fuel system. That & the brakes deteriate fast even when not in use. Make sure the tank is clean. Check all the rubber hoses. If the fuel pump looks old replace it. The old ones were not designed for the ethanol fuels. O-haul the carb if it does not run good. Its a good idea to put an inline fuel filter in the fuel line.
george
Wrenchbender Ret is offline   Reply With Quote
Old 05-04-2019, 12:32 AM   #15
Lokin4AReason
Lokin4AReason's Avatar
Re: Where to start?
I would work start with tyres ( cant drive on flats ), brakes and bearing components ( can stop without hearing the humming noise, with also having attention on the rubber hoses ), cheque for leaks ( as engine oil or water coming into cab ), fuel system and than suspension. just my opinion for starters
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
modification, update, upgrade
