Old 05-05-2019, 10:37 PM   #1
BCOWANWHEELS
hi-cap oil pan question
I,am building a new 350 / 350hp engine for my 72 c10 and have a oil pan question. In order to install a h/v oil pump i need a pan that holds 1-2 quarts more oil. For you fellas that have done this what oil pan did you use. Preferably low-buck type. I,am gonna run a 1 1/2 qt oil filter.
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 05-06-2019, 09:08 AM   #2
SeanB242
SeanB242's Avatar
Re: hi-cap oil pan question
7 quart moroso works just fine.
SeanB242 is offline   Reply With Quote
Old 05-06-2019, 10:30 AM   #3
MARKDTN
I have not done it but I would think the GM Z28/LT1 pan would work.
https://www.carparts.com/details/Che...B&gclsrc=aw.ds
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-06-2019, 10:42 AM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
H-V pump and a stock pan worked forever on my 400sb
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 05-06-2019, 11:10 AM   #5
toolboxchev
I am inclined to believe the OP is concerned about the HV pump running the pan dry. I have heard it before.
toolboxchev is offline   Reply With Quote
Old 05-06-2019, 11:59 AM   #6
Markuli
Markuli's Avatar
I have a 406 build with a Canton 5qt with a scraper, and a Melling hv unit that's been ported, it hasn't shown any signs of oil starvation in the 10 years it's been running. Made plenty of passes down the 1/4 mile.
Markuli is offline   Reply With Quote
Old 05-06-2019, 08:18 PM   #7
BCOWANWHEELS
I,ve got a scraper and windage tray along with lifter valley oil deflector
Old 05-06-2019, 10:05 PM   #8
Markuli
Markuli's Avatar
I need to correct myself- it's a ported melling pump, but it's a normal flow model.
Why do you wanna run a high volume pump? Just curious.
Old 05-07-2019, 12:04 AM   #9
BCOWANWHEELS
to keep pan from emptying.
Old 05-07-2019, 09:50 PM   #10
6T7 C10
I am running this larger pan RNB-264-132 along with this extended length WIX 51794 oil filter on my L31 5.7/350.
6T7 C10 is offline   Reply With Quote
Old 05-15-2019, 09:25 PM   #11
BCOWANWHEELS
I decided to just run the ac delco 2 qt oil filter with stock pan.
Old 05-15-2019, 10:54 PM   #12
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
I'd have to say that the amount of time spent at high revs in a quarter mile probably isn't long enough to empty the pan. Trans-Am racing, I'd say yes. It's the reason the Z/28 got a 9 quart pan. Then again, I had a '64 Malibu SS with a 283 and a Powerglide that I put a 4 bbl and dual exhaust on and ran it at 120 MPH along the coast for many miles without exploding it. Bone stock except for that and an advance curve kit. I bet that farmer who pulled out onto the highway on his tractor right before I went by is still looking for his hat.
~Steven
Simi Valley, CA
Old 05-15-2019, 11:56 PM   #13
BCOWANWHEELS
it takes seconds for a hv pump to suck a pan dry
Old 05-16-2019, 07:36 AM   #14
Mike C
Mike C's Avatar
Almost universal consensus is SBC don’t need nor do they recommend a high volume pump. On all my builds I run the Z/28 standard volume higher pressure pump. Even if I have a large cap oil pan.
THe Z/28 came with a 5 quart oil pan FWIW. It had extra baffles to seal in the windage tray. I have one in my shop.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-16-2019, 11:24 AM   #15
BCOWANWHEELS
do as you like, I do
