Old 05-14-2019, 01:51 PM   #1
Big Kev-O
Big Kev-O's Avatar
Dana 60 question regarding burnouts
I have a 68 GMC C20 with a Dana 60, 4.10. I prefer not to open the diff at this time. I would like to know if it operating properly. If I slam the gas from a stop the truck takes off and leaves a one legger. If I power brake a burnout both tires smoke.
Is this how it is supposed to work? Will a non-locking diff burn both tires? My old Mustang would single leg under all conditions.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 05-14-2019, 01:58 PM   #2
tdangle
tdangle's Avatar
Re: Dana 60 question regarding burnouts
You can verify it is a open or posi type by lifting both rear wheels off the ground and hand rotating one wheel. If the other wheel also spins in the same direction it is a posi unit. If it is open it will spin in the opposite direction. Also you can spin on wheel with the other held from spinning.
A posi will always burn both wheels (if working correctly) An open diff can spin one side or the other and sometimes both.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 05-14-2019, 02:42 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
I’ve never had a working posi that sometimes was a one legger.
Tyler
57taskforce is online now   Reply With Quote
Old 05-14-2019, 02:48 PM   #4
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Your spider gears are locking up and it's going to grenade soon.
J/K
~Steven
Simi Valley, CA
Old 05-14-2019, 04:21 PM   #5
Astro-Balls
Astro-Balls's Avatar
Try putting the Wife in the Drivers seat, and you sit in the passengers seat and see if it still happens...
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 05-14-2019, 05:20 PM   #6
jeffahart
jeffahart's Avatar
Sounds like an LSD. An oil change with proper additive may help a bit. You need to figure out what you have so you can properly oil it.
j
White K20
jeffahart is offline   Reply With Quote
Old 05-14-2019, 07:52 PM   #7
jocko
jocko's Avatar
Are you sure you aren’t just dragging one side (locked) when power braking?
Old 05-14-2019, 08:08 PM   #8
Or one brake is slowly releasing when you let off. Lift and check spinning the wheels, or what I would do is pull cover and see what you have. Dana60s were available with posi unlike the HO52 available with locker.
Old 05-14-2019, 08:51 PM   #9
Mike C
Mike C's Avatar
What does your SPID say? What sort of tags are on the rear diff? Usually a posi even a worn one does two wheels when you get on it but one possibly power breaking.
In 68 would have had a PowerLock for an LSD which is very well thought of and durable. And they increase pre-load on clutch packs under load. This could explain the two track when power breaking.
The 70-72 diffs would have likely had a TrackLok which is not known for being 100k mile durable. But they are cheap and easy to rebuild.
Added: 50+ year old truck most likely needs a diff fluid change... why does no one ever just pull the cover, inspect their diff and refill with new, clean fluid and appropriate additive? I think this is a weekly new thread anymore.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-14-2019, 11:45 PM   #10
Steeveedee
Steeveedee's Avatar
Because differentials are pretty much bullet-proof and tend to outlast the vehicles, I guess. Now that they are 50+ years old, they're showing their age. FWIW, the rear end in my truck is original, and I'm certain that the lube has been changed once, because I did it a couple of years ago.
~Steven
Simi Valley, CA
Old 05-15-2019, 07:39 AM   #11
Mike C
Mike C's Avatar
Well, mine don’t seem to outlast a set of tires sometimes! (That’s not true anymore, but at one time the 35’s and the 4 speed in my Jimmy combined with my youthful age and exuberance ATE 12 bolts. LOL)
But the OP is having a PROBLEM with his diff. This suggests that a visual inspection of the components should be the FIRST thing on the list. He also had questions that could not be answered by the operator so the internet arm-chair quarterbacks could offer hints but the cover needs to come off to answer any questions I think we would all agree.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 05-15-2019, 12:46 PM   #12
70STOVEBOLT
70STOVEBOLT's Avatar
On the back side of the right hand axle tube there will be 2 sets of numbers stamped in. The one closest to the diff will be the date code and the other is the Bill Of Material. This number will be six digits with a dash and one or two more digits. Get me this number and I will tell you what the ratio was originally and if it was a posi or not.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 05-16-2019, 06:50 AM   #13
Like Mike and I have said. Real simple and sweet, pull the cover. Anyone can do it. Once off you inspect what you have for condition and clean while you are determining what you have. If you don't know one from the other, take a picture and show us. On the ring gear is marked the ratio. Now you will know it all and the best part is you get to put the fresh gear oil back in that people tend to never change.
Old 05-16-2019, 11:50 AM   #14
Big Kev-O
Big Kev-O's Avatar
Thanks for the offer. My Daily driver is down for repair so I din't want to touch the 68. I found the number 603067-1. Quick web search tells me it is a 1969-70 Chevy/GMC C20 with leaf springs
open 4.10 ratio.
So it appears my rear is functioning properly! Thanks for all your help. This site is the best.
Old 05-16-2019, 03:18 PM   #15
PepperTreeGarage
PepperTreeGarage's Avatar
open 4.10 ratio.
My '72 DANA 60 was 4.10 open diff. Now 3.73 with Yukon Dura Grip.
PepperTreeGarage is offline   Reply With Quote
Old 05-16-2019, 04:38 PM   #16
Big Kev-O
Big Kev-O's Avatar
Do you mind sharing the total cost? Did you install that beast?
Old 05-16-2019, 08:02 PM   #17
Mike C
Mike C's Avatar
I have a '70 Longhorn parts truck that should have been 4.56 No-Slip and it was a 3.73 open, so you never know what you got for sure.
My '86 K30 had 3.73 tags on both the Dana 60 front and Dana 70 rear but somebody had scratched out 3.73 on the SPID and written 4.10. Sure enough, when I pulled the covers to put lockers in it had 4.10s. Why they put the 3.73 tags back on no one will ever know.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 05-17-2019, 12:26 AM   #18
PepperTreeGarage
Did all the work myself except the install of the ring and pinion. My neighbor helped me with that. He owns Batey Racing and works at Ted's Rod Shop. As far as cost. Lots of money. I did a complete rebuild, including brakes. My labor is free...LOL and Bill donated his time aswell. The price for the Yukon 3.73 ring and pinion was $436.00. The Yukon Dura Grip was $613.00. A master rebuild kit was $286.00. There were other parts aswell. Here's a few pics of the process...….
