Old 11-28-2003, 10:17 PM   #1
grnddwn
belly dragger
grnddwn's Avatar
cylinder bore size question
What is the easiest way to tell if my block has been bored over
grnddwn is offline   Reply With Quote
Old 11-28-2003, 10:39 PM   #2
frogsmakr
frogsmakr's Avatar
look for .30 or .60 or similar stamped on the pistins
67 C-10 shortwide
'06 Triumph Thruxton
'09 Harley 'Lectra Glide
'95 Z-71 two door Tahoe
frogsmakr is offline   Reply With Quote
Old 11-28-2003, 10:47 PM   #3
jmanz69
Careful, they attack...
jmanz69's Avatar
The stamp will be on the top of the pistons, usually under whatever carbon crud is on them. If the pistons are gone, then go to the nearest parts store and buy a cheap dial caliper. Then use it to measure the bore. It won't be exact, but it will let you know if it's oversized. a 350 small block has a standard bore of 4.000 inches. Check all the way around the cylinder, as the bore may be slightly out of round if it's really worn. Best way is with the pistons as stated above.
jmanz69 is offline   Reply With Quote
Old 11-29-2003, 12:20 AM   #4
grnddwn
belly dragger
grnddwn's Avatar
