At the body shop.
ORD steering brace
NOS manual box on added an ORD box brace.
Strange enough the frame wasnt already broken.
" That didnt make it any newer " " Dont antique the equipment " |
Re: ORD steering brace
every one of my trucks gets a ord brace kit .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
At the body shop.
Test drove it after changing the oil.
No more death wobble. 🙃
How do you overpower the steering box on a 2 wheel drive truck? I have seen C10's take ridiculous abuse and never cracked a frame around the steering box. I can see putting them on 4WD's but I don't get the 2WD's.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
85 2wd of mine was broken when i purchased the roller truck to build up . i had to weld it up and use the plate kit to fix it . even had a crack in the lower rail lip at the first of 3 bolts that holds the crossmember to the frame .
At the body shop.
My 77 was broke
Brothers 78 was Our 68 is broke Was really surprised my 73 wasn't
At the body shop.
Broke nearly off at the front crossmember on the 78
I have been thinking about doing this on mine as a precaution. How is the fit and finish?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
At the body shop.
Nicest aftermarket stuff I've installed recently.
Needed a spacer between it and the factory crossmember. Tightened up the steering considerably, but changed the box the pitman arm and added the brace in one shot.
the ones i have installed just the bolt in brace kit and nothing else ..... they are much more firm in the feedback not as spongey . taking out the frame flex in this area does a lot .
