07-09-2019, 12:17 AM | #1 |
A/c lines and hoses on a 67
All the hoses in the trucks I have seen, most 70 to 72, have had the hoses clamped when they were made. On my 67 it looks like they used special hose clamps with a tab on them to locate the clamp spot. I assume this is factory. Will these leak continually or will they work? This is the only truck I have ever seen this on. Any one still have this on their working ac system?
07-09-2019, 09:53 AM | #2 |
Re: A/c lines and hoses on a 67
I still have these on my 69 GMC. They seem to be holding just fine. I do plan to swap to clamped hoses once the begin to leak.
07-09-2019, 10:50 AM | #3 |
They were on my '69, but I replaced them with the crimped type when I restored the truck since that's all that I saw available. They had worked fine with no leaks for 40 years.
07-09-2019, 11:06 AM | #4 |
That's awesome. I had my ac stuff restored about 5 years ago by faBenny. For some reason I thought I'd get crimped ends like the newer stuff but I got it back just as it was with new clamps. If it works I may just put it back this way.
07-10-2019, 09:57 AM | #5 |
Old member
They didn't start crimping until the 70's not sure what year though. My 71 has crimps but I had all the lines made myself.
My 64 SS Impala had factory AC and all the lines where clamped with the special clamps and it worked fine. When I re did the lines I crimped all of them but 2. They still have the old screw type clamps on them.
07-10-2019, 10:05 AM | #6 |
Carpe manana
Note how the OEM AC compressor harness plug above is located at 11:00 - all the over-the-counter rebuilt compressors I've looked through have it located at 1:00
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 07-10-2019 at 01:44 PM. |
07-10-2019, 11:27 AM | #7 | |
One thing I don't ever recall seeing any discussion on is the fact these trucks used 2 different types of mounting brackets. Not sure when the change was made, but my early '69 used what I refer to as the earlier style that bridged the right side valve cover. Last edited by FirstOwner69; 07-10-2019 at 11:46 AM. |
07-10-2019, 01:49 PM | #8 |
I would use crimped hoses. You will have less leaks over time.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
07-10-2019, 02:01 PM | #9 | |
I would think that if you did periodic checks on the tightness of the clamps that it would lessen the chance of leaks. |
