Active Member
![]() Join Date: Nov 2015
3,973 mile road trip in 15 days
I’ve been scrambling to get my truck ready for a trip from Springfield, MO to Atlantic City then Pittsburgh then York then State College then south through Louisville and back to Springfield. 2 weeks before I left I put front airbags on. Weekend before I left I switched rearend to a open 3.07 from 3.73 posi. Sunburnt left arm plus crazy heat wave with no A/C was fun. Camper tonneau cover held up but one of the wooden supports broke. Debris on the highway punched a little hole in the camper aluminum. I fixed it for the time being with jb weld. Through Indiana I got 21 mpg. I got to go to the Columbus Goodguys show, which was amazing to see that quality of work/money. Got to ride some fun skateparks. Also went off tossing to a campsite one night and scalped the ground for awhile. Sleeping in the camper when the feel like temperatures were 110 is like a oven. I fixed the wing window for my girl but by the end of the trip both windows were struggling hard to wind up. Also all the bumps loosened up the screw that holds my turn signal on. Which meant at random times (in traffic) my lever would ground out my horn which was awkward. I went with the theory that if I brought tools then I would have issues so I only brought some line wrenches. Amazing times out there remember these trucks are meant to be driven to enjoy. Finished off with doing a bike show in Houston Mo.
Posted via Mobile Device |
Active Member
More pictures
Active Member
More fun they even let me park my truck behind the ramp if you zoom in real far.
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: 3,973 mile road trip in 15 days
Sounds like you had lots of fun. I'm glad you got to take your truck and make some good memories with it.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
![]() Join Date: Aug 2004
Awesome road trip! It’s nice to really get out there and get some miles.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
![]() Join Date: Jan 2009
I did 1200 miles in one day. Solo.
Go Pack Go!
Your board name says it all, I bet you had the thrill of a lifetime!
Active Member
Old member
Nothing better than driving these old rig's.
I have drove mine now 5 times on the Hot Rod Power Tour and each time put over 2000 miles on her in less than 8 days! It's made each trip without any problems. Well no major ones. I had a AC switch stop working on one trip and had the front sway bar bushings replaced this last time in June. Nothing better than seeing the USA in a Chevorlet! Even more so in a C10! ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#10 | |
Active Member
Old member
You'll like that addition for sure.
Were you doing a buck, twenty in that pic, or did the needle just somehow get on the wrong side of the stop?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#13 |
Its a Truck Thing......
Sweet topper!!!!!
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
#14 | |
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
#15 | |
Active Member
I did the s10 speedo swap and I just haven’t pulled gauges back out to reset needle yet. Posted via Mobile Device |
#16 |
Oh, ok. You just need to pull the little stops out, then power the speedo up and see where the needle moves to. If it does not go to 0, then with it still powered up, pull the needle off and reset it at 0, that should fix it. Then dont forget to put the little stops back in.
