Old 07-29-2019, 10:19 PM   #1
slammed57
tail gate question
What is everyone doing for when you close the tailgate and keep from the paint getting chipped for metal on metal? I'm guessing some type of gromet? but I don't see where one might go.
slammed57 is offline   Reply With Quote
Old 07-29-2019, 10:36 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: tail gate question
My IH has bump stops like these..I'm gonna do the same with my mar-k bed parts...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-30-2019, 11:32 AM   #3
slammed57
hey greg, hows it goin....its very tight.. i belive the gromet your talkin about will push the tailgate out too much.. I thought of one of those flat hood gomets.. just wondering if someone came up with somthing
Old 07-30-2019, 11:46 AM   #4
mongocanfly
Post Whore
The ones that were on the IH stuck out a quarter of a inch...since they dont make new ones for it I had to get what I could...new ones I got stick out a half inch...I'm just gonna sand them down thinner once I get everything done..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 07-30-2019, 01:20 PM   #5
slammed57
Ahh good point! that would probably work
Old 07-30-2019, 02:18 PM   #6
b-mac
b-mac's Avatar
How about a few of those clear rubber stick on things for cabinet doors?
Being inside of the tailgate like that, they probably won't see much sun or the power washer.
b-mac is offline   Reply With Quote
Old 07-31-2019, 08:26 AM   #7
Divine 59
^ I agree with b-mac.
My Build Thread http://s95.photobucket.com/user/drop...?sort=3&page=1
Divine 59 is offline   Reply With Quote
Old 08-02-2019, 08:16 AM   #8
my56chevytruck
my56chevytruck's Avatar
as you said, To thick of a rubber grommet you may not be able to close the tailgate completely. I had to grind down the height of a pair I had that were for the hood of my 40 ford.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 08-02-2019, 10:09 AM   #9
dsraven
the little rubber bumpers from a modern fuel door may work. some are solid rubber so they could be trimmed down to the thickness you want. they fit into a small hole as well.
Old 08-02-2019, 10:11 AM   #10
dsraven
some foam tape on the vertical section of the box, in the bend area, may also work and not look unsightly if done well. like weatherstripping you can buy at home depot in different thickness. if you don't like it just peel it off.it will hold water though, like a sponge.
Old 08-02-2019, 07:23 PM   #11
Coupeguy2001
Coupeguy2001's Avatar
I used foam tape that was 3/16” thick.
It squished down to 1/8”.
Made the strips about an inch long.
Works great!
Don’t drive it in the rain, so not a problem!
Coupeguy2001 is offline   Reply With Quote
Old 08-02-2019, 07:29 PM   #12
Coupeguy2001
Old 08-02-2019, 09:35 PM   #13
1project2many
I like to use clear rubber dots.
https://www.amazon.com/Protect-Cushi...18314984&psc=1
There are different styles and sizes so there's probably one that fits what you need.
1project2many is offline   Reply With Quote
Old 08-05-2019, 07:38 PM   #14
slammed57
thanks all for the responses. the clear cabinet style is a good idea but I am afraid with living in Florida and the summer heat it will heat up the adhesive and fall off. So I came up with this, I'll pass it on maybe someone else can use it ... it a hood gromet cut down and slightly hit with the grinder to thin it up a bit. drilled a 5/16 " hole and put in
Old 08-06-2019, 11:24 AM   #15
57tailgater
The rubber bumpers for the glove box door are pretty small and may work too.
57tailgater is offline   Reply With Quote
Old 08-06-2019, 11:47 AM   #16
mongocanfly
Post Whore
thatll work...looks good..!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-07-2019, 11:33 PM   #17
my56chevytruck
Looks great Mike. I tried the adhesive ones here and like you said, they fall off. would only be sooner there in Florida.
1940 Ford Dlx Coupe
1969 Mach1
Old 08-08-2019, 12:17 AM   #18
Dan in Pasadena
Dan in Pasadena's Avatar
I used the green stick on felt dots they sell for cabinet doors. My truck is always in the garage so they should stick for awhile though not forever.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
