08-05-2019, 02:58 PM | #1 |
Welding and AD Dash...
I had to replace the dash in my 47 because of a "farmer" dash the PO had installed (I needed to go back to stock). Now, I want to fill in the radio hole, and the knob holes. IF I have a radio, it will go below the dash, or not at all. Either way, the holes need filled. What is the easiest - best - way to go about filling those holes? Thanks!
08-05-2019, 08:21 PM | #2 |
Post Whore
Re: Welding and AD Dash...
The best fix you can do is cut some patch panels and weld them in the opening...you'll need a mig welder and go slow to help prevent warping...probably need a little hammer and dolley work ..then epoxy primer and some filler to slick it out...some more primer and your done
08-05-2019, 11:33 PM | #3 |
The best and easiest way is the way the factory did it - with a radio delete panel:
1951 Chevy Panel Truck |
08-06-2019, 01:18 AM | #4 |
That would be the correct way with a stock dash.
08-06-2019, 11:26 AM | #5 |
Post Whore
that delete panel is cute....but worthless if your dash has been hacked out like most ive seen are....but if its the factory opening it would be ok
08-06-2019, 10:16 PM | #6 |
It has the "factory opening", BUT there are two extra holes drilled in the dash to accommodate a wider radio. I figure I am gonna weld them shut, so might as well do the opening while I'm at it - unless someone has an extra delete panel handy....
08-07-2019, 01:23 AM | #7 |
Weld away then. Complete info and maybe a clear photo always gets a more accurate answer the first time around.
