Sbc headers
Hello
I'm Martin and I'm working on a 64 c10 I'm am working on airride and now I'm having a problem I've got a 350sbc with hooker competition headers and they are two far under the frame Now I have seen a set of 88-95 truck headers that are shorter But before I buy then does anyone know if they will clear the frame Rest of the exhaust will be build new Thanks |
Re: Sbc headers
Pictures
Re: Sbc headers
Do you have a better pic of your motor.
Zoom out a bit so we can see the complete drivers side with the header. |
Re: Sbc headers
Im building a fully bagged 66 with a sbc..Ive heard and will be trying Hooker 2466HKR headers..They are more of a clipster style and what PBFAB recommends to some...fyi...
Moderator
![]() ![]() Join Date: Aug 2011
Re: Sbc headers
Headman 69230.
http://67-72chevytrucks.com/vboard/s...1&postcount=16
Re: Sbc headers
ChadW, I too have read the Hooker 2466HKR's work well for our trucks, so I put a set on my '66. Just wanted to share my experience with you.
They did not clear the motor mount stand on the driver side, so I had to notch the top of the stand out and re-shape it with some scrap steel. If it makes any difference, whoever put the engine in my truck used the rear bolt holes for the stands. They also won't clear the factory column shift linkage. I used the Lokar style kit from CPP, if I recall correctly. The passenger side collector interfered with the seam/pinch weld/whatever its called at the firewall toeboard as well, which I was able to trim off with a sawzall. |
#7 | |
Re: Sbc headers
Re: Sbc headers
Sounds like you may not have much to worry about then.
I like the headers overall. They seem like decent quality, aside from the crappy paint that comes on them, and they don't hang down in the way like full length versions. The transmission in mine is a TH400. Tuff with two F's, but leaks like a sieve. |
Re: Sbc headers
I have heard Dougs headers tri-y are supposed to be the ones to get for lowered trucks.
There is more then one way to do it right ! |
#10 | |
Re: Sbc headers
The rear header bolts on both sides are a real pain. I bought 12pt, 5/16 head ARPs which made it easier. Pulling the valve covers helps get those last ones tight.
Denver/Big Island -- Instagram: Slammed64c10 '46 Fleetmaster Coupe '66 C10 w/355sb/700r on Ridetech Air Ride '64 C10 on GSI Bagged Chassis, 408 stroker w/twin 64's - in progress |
#11 | |
Re: Sbc headers
I'm kinda glad I'm not the only one that ran into these issues. Misery loves company lol. |
Re: Sbc headers
#13 |
Re: Sbc headers
1970 Chevelle headers tuck up real nice and clear everything.
Our 1965 GMC big block pro mod build http://67-72chevytrucks.com/vboard/s...d.php?t=746098 |
| Bookmarks |
