Old 08-20-2019, 10:58 PM   #1
Ecartman84
How the hell do you install this????
I am not having any luck installing this on the passenger side of my 72's bench seat.
Ecartman84 is offline   Reply With Quote
Old 08-20-2019, 11:03 PM   #2
Astro-Balls
Astro-Balls's Avatar
Re: How the hell do you install this????
Hard to do with the seat in the truck, basically slide the spring over the square seat latch bar, compress the spring, and install the Key into the slot and let the spring capture it.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 08-20-2019, 11:54 PM   #3
Ecartman84
Yeah, it sounds so simple but it is a pain with the seats in the truck.
Old 08-21-2019, 12:39 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Make sure that the key (square piece) is all the way out when you try to put it together. It is easier with 2 people. Push on the key from the inside of the track while you slide the seat back and forth a little. This will let the key slide all the way to the outside. Hold it in that position while you assemble the spring and keeper. This is next to impossible for one person to do with the seat installed.....
I will include a couple of pictures of the parts with this post. The first picture of the parts assembled is looking at the bottom and the second picture is looking at the top.
LockDoc
Leon
Old 08-21-2019, 07:12 AM   #5
There was a You Tube video on this but the guy threw his camera and broke it before he got through it
Old 08-21-2019, 08:04 AM   #6
jbarron
Can you zip tie the spring in place and then cut it off after getting it on
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors
'72 3/4 Cheyenne Super 350/200R4
'50 1/2 Chevy 3 Window
jbarron is offline   Reply With Quote
Old 08-21-2019, 08:17 AM   #7
dmw319
maybe a stupid question, but how does it work? how do you move it in order to slide the seat?
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 08-21-2019, 08:28 AM   #8
palallin
You compress the spring (freeing the détentes) using the handle on the other side as a lever.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 08-21-2019, 11:22 AM   #9
LockDoc
LockDoc's Avatar
There are pictures in this thread that will give you some idea.
http://67-72chevytrucks.com/vboard/s...d.php?t=418802
LockDoc
Leon
Old 08-21-2019, 08:44 PM   #10
Ecartman84
LockDoc
Thank you for the great pictures! It sounds like I am doing it correctly but I think that the issue is I am trying to do it by myself. I will have to ask someone to hold the key in place while I try to install the spring and clip.
Thanks!
Old 08-21-2019, 11:24 PM   #11
LockDoc
LockDoc's Avatar
Thanks!
No problem. Let us know how it goes for you.
LockDoc
Leon
