09-05-2019, 01:17 PM | #1 |
Let's see your favorite rear fuel tank filler options
As I get closer to making this pile of parts look like a truck, I need to get a rear tank going. Filling through the bed seems easiest to manage, but there are many cool options. Post your favorites below!
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
09-05-2019, 01:20 PM | #2 |
Re: Let's see your favorite rear fuel tank filler options
Cool through-the-bed option made to blend in:
09-05-2019, 02:51 PM | #3 |
I dig the magnets ^^^
Here's my panel access to under floor filler neck. PS: Don't worry folks; the filler neck is not inside the cargo area, just the door to access it below the floor.
1951 Chevy Panel Truck Last edited by MiraclePieCo; 09-05-2019 at 05:12 PM. |
09-05-2019, 04:37 PM | #4 |
I just order this one. Came in last night. Looks sharp.
http://www.tanksinc.com/index.cfm/pa...rod/prd475.htm |
09-05-2019, 04:53 PM | #5 |
Mines in the fender.
09-05-2019, 06:22 PM | #6 |
09-05-2019, 07:57 PM | #7 |
We went with a fairly simple filler.
09-05-2019, 11:13 PM | #8 |
From the local marine supply...
09-06-2019, 02:21 AM | #9 |
The '50 pickup I did. The other plate is a battery access cover.
1951 Chevy Panel Truck |
09-06-2019, 09:29 AM | #10 |
On my 1940 Ford. Both stainless inserts are flush with top of wood.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
09-06-2019, 03:38 PM | #11 |
I put mine in the stake pocket of my fleetside.
09-07-2019, 09:15 AM | #12 |
Since my suburban gas tank's fill neck bends to the right of my rear truck fender, I bought a Harley Davidson gas cap and mounted it to the right rear fender. It mounts flush, pushes in and screws tight.
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
09-08-2019, 02:13 PM | #13 |
similar to idbeast, truk has the filler door in the fender
as a tall guy i sort of wish i had put it in the top of the fender looked like a great location on sawhorses
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-08-2019, 06:20 PM | #14 |
I like how you did the wood on top of the side bed supports, how did you secure the wood to the bed support?
09-08-2019, 07:20 PM | #15 |
Fords are different from Chevies, at least in 1940 they are. Plus it's back halfed. There's a 1"x1/8" steel frame work under the wood. Just pre drilled holes in the supports and screwed the wood down from below. I didn't want any bolt heads showing above.
09-08-2019, 07:45 PM | #16 |
Although I'm mostly a Chevy guy I really like the looks of the 1940/41 Ford pick ups
09-08-2019, 11:45 PM | #17 |
I went around the backside of the fender. I’d recommend moving it up an inch or two to make the fuel angle a little steeper. This is a slow fill.
1955 second series, 3200 standard bed, big window. Owned since 1975, decided it was time to do a frame off. 327, 4L80e, Ford 9 inch. |
09-09-2019, 09:09 PM | #18 |
I've been getting questions about how I have my filler neck inside the cargo area. Again, THE FILLER NECK IS NOT INSIDE THE CAB - ONLY THE ACCESS DOOR! The filler neck is below the floor, the cap is sealed and the tank vented into a wheelwell. While I may look like I huff gas fumes all day, I assure you I don't.
1951 Chevy Panel Truck Last edited by MiraclePieCo; 09-09-2019 at 10:43 PM. |
09-10-2019, 12:13 PM | #19 |
You guys have seen this kit?
09-10-2019, 01:57 PM | #20 |
ran from dallas to nashville, with a guy that had this. he hated it, had to unload 80% of his truck each time he fueled. he had a bbc that sucked gas to boot, he fueled 3x to my one tank
09-10-2019, 04:18 PM | #21 |
here's mine. old fuel door from an scrap envoy. door was flat to start with. a little fun getting the shape on the fender and the perimeter ring cut from the donor.
09-10-2019, 04:24 PM | #22 |
hey ogre, did you use the stock spare tire carrier mounts or custom fab a new one. wondering the diameter of the tire you use as well. looks good. my spare tire mount is long gone but will fab something if I can't find a good used one. may not work with my box anyway. my tires will be 235/60r17, so 28.1" tall. hope the spare fits without hitting the cab.
I always thought your truck was a cool design, a truck with a trunk. cool. |
09-10-2019, 08:36 PM | #23 |
Thanks so much bud. your bed wood came out very nice
09-11-2019, 11:35 AM | #24 | |
You could split the board at one of the cross-sills. You would have to do the whole bed length. |
09-11-2019, 11:42 AM | #25 |
that bed filler on the green truck looks really showy, great for a low use unit I guess. very tiddly looking. my truck will be a daily driver if I ever get it done before I have to surrender my lic, haha. I plan to use the box for stuff so the fender mounted gas door is a must for me. besides, we get snow up here and it is one more way to get water in the tank when filling. sure looks good though.
