Post Whore
![]() Join Date: Aug 2014
TH400 transmission cross member / bracket vs TH350 for a Camaro subframe
Hi All I have this question posted in my '54 build thread but it may get better attention here
I ordered this first gen Camaro TH400 transmission cross member like an idiot, not thinking who would cut up a first gen for a frame swap, so I recon my front end is off a second gen Camaro anywho, I believe the TH400 is like 3" longer than the TH350 cause the bracket that showed up wants to sit about 3" forward of where it needs to bolt up to the transmission tail housing so what cross member do you recommend for the TH400 if I don't want to put any more holes in the frame (if possible) |
Re: TH400 transmission cross member / bracket vs TH350 for a Camaro subframe
it looks like you were planning to bolt that to the underside of the frame, correct?
I suggest you use a ratchet strap or something (through the truck floor?) to support the trans where the cross member should be and mock up the truck so it is sitting at ride height with power train installed and with enough room under it to work. roll the truck back and forth some, at least a couple of turns of the wheels so it gets it's suspension "set". measure the rake angle of the truck with it sitting on the ground with the weight of the whole truck sitting on the suspension so you can re-create that same angle when it is on blocks. not absolutely required but it makes it easier to level things up and get the engine/trans angle correct without doing a bunch of math. if you have air bags then this step is prolly not required because you can simply set the rake angle you want by adjusting the bags later. the thing is to know the rake angle before you start so you can get the engine sitting at the angle that most oil pans/oil pick up tubes, carbs etc are made to work at. now support the engine and trans using a floor jack or some cribbing or whatever you have to support the trans end of the power train since there is no cross member right now. you can release the temporary ratchet straps from before and adjust the cribbing to get the power train angle you want. usually about 3 deg down at the rear. this is usually the angle that engines need so the carb will sit level and the oil pump will be able to pick up oil from the pan properly and the crankshaft won't be running in engine oil if the angle is extreme. some will say use whatever angle you want and that is up to you. it's just a recommendation. now that you have the power plant sitting at the right angle you should square it up with the frame. you want the engine fore to aft center line to be parallel to the frame whether it is offset to one side of the frame or whatever. the frame on your old truck may be tapered at the front so you are basically getting the power train running at the same plane as the frame is running in. you should do a few dimension checks on the frame to ensure it is square and straight before you proceed. see below link. https://www.tersenyum.co/47-54-chevy...me-dimensions/ also check the rear axle to ensure it is 90 degrees to the frame so the engine and rear axle are also going to be at 90 degrees to each other. this is important for the driveshaft u joints to work correctly. actually, theoretically, the engine and rear axle could be at whatever angle to the frame as long as they are at 90 degrees to each other. you need the frame to be at 90 degrees to the frame so the truck will run down the road straight and the front end alignment can be done properly. you can use a plumb bob and some marks on the floor to figure this all out. -drop a line and mark the floor at the engine pulley center and the trans output shaft center. draw a line that connects the 2 and extends out past the rear axle. -drop a line from the rear axle at the same spot on each side, like the wheel mounting flange axle center (important to be the same place on each side and at the center of the axle center line from side to side). draw a line to connect these 2 points. -if your power plant is centered in the frame then the dimension from the axle points to the trans output point should be the same on each side. this assumes the rear axle is not offset and is square with the frame as well. you could drop a line from the frame to check if the axle is offset and repair as required first. if the axle is offset the truck will dog track when driving-meaning the truck will go down the road slightly sideways. -if the power plant is not centered in the frame, like offset to one side, then use some geometry skills and figure out if the axle is square to the power plant center line. measure the dimension from the axle center line to the trans output mark and make a point, on the power plant line at that same dimension, behind the axle. you can basically make 4 right angle triangles if you connect the dots between the axle dots and those 2 dots. assuming the axle is square and centered in the frame, you need to move the trans output over to make the triangles the same in front and behind the axle on each side. this means the dimension from the axle flange to the trans output dot and the other dot behind the axle should be the same dimension. if the axle is offset then this dimension will be different from left to right but should be the same per side. this can mean a bunch of marks on the floor and new lines run each time you move the trans over so a concrete floor would be nice. -now that you have the power plant square and parallel and at the correct down angle, use some ratchet straps or blocking or whatever, from each side, to keep the trans sitting exactly in that spot side to side sitting on the cribbing so it can't move up or down. measure the dimensions and write them down on something so you can keep checking as you build a new cross member. -install your trans mount insulator (the rubber part on the trans). -make a flat metal pad for the mount to sit on. you could easily copy the one from the new cross member with the slots etc in the correct place and at the correct spacing etc. -bolt that pad onto the mount and place it so that the mount is sorta in the middle of the slots to allow some adjustment later. remember that one day somebody will want to remove the trans pan for servicing so try not to make that a difficult task by making it hard to access the bolts. -now you can use some poster board or a piece of plywood or whatever to make a pattern for a cross member that will bolt to the frame where you want it and connect to the pad you built for under the trans mount. ensure you leave some wiggle room for how much squish the mount may have with the weight of the trans etc on it. remember the trans pan will need to be accessible and you may need to leave room for the other stuff like exhaust. I personally think the cross member should be bolted to the upright part of the frame cross section (web) for strength and because holes drilled in the flange of the frame weaken the frame more than if they were in the web simply because there is less material there. there are lots of guys who drill the flange though and are trouble free. there are also universal cross members out there which have 2 bolt on flanges with a short section of tubing welded on at a 90 degree angle and then a section that goes between them which has the mounting pad welded on. the connector part is usually too long long so it is a cut to fit thing. it can fit to your truck and then be welded where the tubes join or cab be bolted together I suppose. they come in different amounts of drop to accommodate different drive system,configurations. you are basically copying that by doing the above. don't forget to leave room for exhaust pipes and shift linkage (if cable or floor shifted), under floor brake boosters if equipped, under floor battery if equipped etc. think about where and how your fuel and brake lines will run, wiring to the rear etc. https://www.tdotperformance.ca/trans...0aAtEUEALw_wcB https://www.summitracing.com/int/sea.../universal/yes here is a quick video showing the welders series universal mount. since the USD is really good compared to CAD (welders series is Canadian), these may be a cheap way to go as well. they have an online catalogue as well as some videos and have a vast array of universal fabrication gussets, brackets etc. also have other hotrod building stuff like 4 link kits, C notch kits, tubular rods and adjustable ends, urethane bushings, MII kits etc. https://www.youtube.com/watch?v=dNXxcsyjkX8 https://welderseries.com/Parts-&-Pieces-c13305849 interesting videos on different hotrod themes https://www.youtube.com/playlist?lis...65IXLfPvUzW8MA welders series step notch being done by a guy in his garage on a truck like yours https://www.youtube.com/watch?v=JZUVnCFhXIQ another done by welders series tech https://www.youtube.com/watch?v=7aKMV2Zivxw |
#3 | |
Post Whore
WOW! Thank you so much, allow me to answer you one issue at a time.
I think the proper way to install this cross member is to have it point towards the front of the truck, but if I do that it is not wide enough so I will have to extend both sides, but even then there are no pre existing holes in the camaro subframe to accommodate it this way. I don't know jack about Camaros so I don't know if the late second gens even came with the TH400s. Oh well, I enjoy the learning process. thanks again for all your words, I am still digesting the rest of them |
![]() Join Date: Jul 2007
Normally a Camaro trans crossmember isn't going to work with subframe swap. That would depend on how the subframe was installed though. One like what Dsraven suggested is the way most of us would go.
Do a search for that part number or any part number though as you can get that unit for 57.62 plus 10.99 standard shipping from Jegs on Ebay. You may not need the six inch drop so do as he said and with the truck on stands level the engine up (carb mounting flange on intake or top of airhorn on carb and measure as he said to. They make them with several drop distances so you can come out real close with minimum drop.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 09-12-2019 at 11:28 PM. |
If you have Amazon prime you can get a good price too they show several drop distances. https://www.amazon.com/Trans-Dapt-45.../dp/B000CPZWDS
Post Whore
here's an interesting piece of information that I found on this site http://www.brphotrods.com/products/2...cts/index.html apparently there were two different crossmember mounting locations on the second gen Camaro subframes depending if it was the 1970-74 Early Style or the 1975-81 Late Style. I recon hardly anybody would butcher the Early ones, so most likely mine and most of youz is the Late Style.
now I realize that I will have to make something custom but this is just some fun facts, I think the Camaros came with a SBC 350/TH350 combos or Big Block / TH400 but I doubt they had a SBC 350/TH400 Option like mine in the 75-81 Late Style. Last edited by Gregski; 09-14-2019 at 02:29 AM. |
Post Whore
so beating a dead horse to death I finally found some documentation on which way the OEM Camaro crossmember should go/face, the pointy end to the front, ha ha
http://www.pozziracing.com/Media/72camaro_sub_dim.jpg |
Post Whore
and I also found the Camaro Transmission Crossmember, Small Block With TH400, 1970-1973
Replacement for OE #: CM01-70 Part #: 33-351985-1 from Eckler's so I emailed their customer support to see if they have one for the Late second gen. |
Post Whore
sharing is caring so here we go, so a little secret for you all, sometimes I like to take a Thursday off work and work on my truck in peace or go to the junkyard, you see the wife is at work, the kids are at school, and it's just me, in the garage
ok, having said that, last time I went to Pick n Pull I bronged home two more transmission crossmembers now what in the world did you done that for Greg? well I wasn't too a happy with the way I was mounting the trans with my old crossmember so I thought I could do better so here is my collection 1. my old original Muncie SM465 4 speed cross member aka da Double Humper for 2WD 2. Turbo 400 TH400 automatic transmission for 2WD cross member 3. Turbo 350 TH350 automatic transmission for 2WD cross member 4. automatic transmission cross member for a 4x4 aka 4WD |
Post Whore
now that one on top the Double Humber is by far my favorite crossmember but it hold court in my beloved '74 effectionately named Rusty, so I had to done did what my mima always said, Run what you Brong! and so we begin to massage the 4x4 one on the bottom
by the way if I called these brackets something in error, by all means please correct me especially in the 4WD world as I know nothing about spinning no four wheels at once madness LOL had to fill in all these holes first as the TH400 tailshaft holes are 4 1/4 on center and would not match up, so this added some strengthability to the design |
Post Whore
ah yup, Grinder and Paint make me the Welder I Ain't !!!
but since this on the under side we may just leave the heavy beads for strength, now was this wire too fast or not enough heat, I had my little Lincoln C140 spark machine on the highest current, but I was too lazy to change to the .030 or .035 wire from my .025 |
Post Whore
low and behold I actually drilled two perfect holes for once, the first time in my life, I am getting so good at this, Ha ha
Fun Level = 9 |
#13 |
Post Whore
she was a bit of a Conservative (ie leaned Right!) hey I'm just messing with you don't need to go all Politically Correct on me, hee hee
that's a 1/4" solid rubber sliver to pretend she's rubber mounted |
#14 |
Post Whore
all of this so far is Moch Up and not permanent, I will set her on the ground on all fours and measure the angle of the dangle, the problem is my silly water run off in the garage is ridiculous it's like 6" in 22 feet, first world problems I know right, I will figure out a way to level her out
#15 |
I would suggest to grab a real trans mount and install before too much mock up is done. the regular trans mount will provide some good sound and vibration insulation as well as protect the casting on the tail shaft housing under heavy load/unload.
less drone in the cab equals a better ride and less deafness so you'll be able to hear the wife when she calls supper is ready, lol. |
#16 |
I second that motion on the real trans mount.
That is just too slick using that piece though.
#17 | |
Post Whore
1. the crossmember does not have enough drop in it to allow me to raise the trans that far up without hitting the trans tunnel and also the driveshaft would pound the cab, hence the almost rigid mount solution (attempt) 2. the TH400 trans mount would not bolt up to this 4x4 crossmember it was different bolt spacing, this 4x4 is one strange animal I am posting all this feedback as it is almost ridiculously too difficult to do this, and I have installed a transmission or two in my day, ha ha |
#18 |
Post Whore
#19 |
I think I would have made a recess for the mount to get it down to the height I needed and still have a mount.
With the way you have it, I'd suggest cutting another piece of rubber to put on the bottom side of the crossmember and cut and drill a piece of flat bar to have rubber on both sides of the crossmember to let the trans wiggle a tad. Pretty much like the donut mounts on TF stock engines where there there is a rubber piece above and below the mounts to act as a two way cushion. Otherwise when the engine torques you might overstress an ear on the extension housing.
#20 |
Post Whore
that actually sounds like a brilliant idea, thanks mate
#21 |
For another option, check out my build. I installed my Camaro subframe the same way as you and I used a Welder Series Crossmember kit as a starting point. I. If you are planning on an underfloor master cylinder/booster kit, make sure you have that mocked up before you fit your crossmember in. I'm going to be running a small block and a 700r4. It got a little tight under there with the CPP underfloor power booster but it all fit. If you are planning on a firewall mounted master cylinder/booster it opens up a lot of room.
My Build Thread: 59 Apache - Lifelong obsession http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession |
#22 | |
I would take the time and drop the crossmember down and use factory style mount. An ounce of prevention is worth a pound of cure. Or do it right the first time will keep you from doing it again. |
#23 |
Post Whore
grinder and paint, make me the welder I aint
