09-23-2019, 07:35 PM | #1 |
66 C10 Holley 750 Throttle Cable Connection
I have a Holley 750 while using 67/72 throttle cable and pedal.
Looking how to finish the connection between the 2 Photo attached |
09-23-2019, 08:19 PM | #2 |
Re: 66 C10 Holley 750 Throttle Cable Connection
09-24-2019, 01:46 PM | #3 |
Connect it with an e clip to that post that has a groove in it is how I connected mine. I'm using a squarebody pedal, but same general idea and cable type
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
09-24-2019, 03:05 PM | #4 | |
It moves independently from the throttle lever. |
09-25-2019, 12:12 AM | #5 |
Ah, did not know that. In that case, completely ignore everything I said Sorry about that, I've never worked with a Holley before
09-25-2019, 06:00 PM | #6 |
here is mine. I used original linkage.
09-27-2019, 07:34 PM | #7 |
i used these https://www.speedwaymotors.com/Speed...hings,613.html and a 1/4 inch bolt and lock nut hope this helps
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
09-29-2019, 06:51 PM | #8 | |
Got the bracket Fits great What should i use to connect the cable to the bracket so it pivots correctly without binding? |
09-29-2019, 09:48 PM | #9 |
Likely like bama did with a bolt and jam nut.
