Old 09-23-2019, 09:12 PM   #1
bigmac73
bigmac73's Avatar
4l80e infi
Guys,
I have been thinking about swapping out the th350 for a 4l80e transmission. Weighing the pros and cons...
Any thoughts are appreciated
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 09-23-2019, 10:12 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: 4l80e infi
Massive leap in technology in this swap...
Many questions:
Engine it will go behind?
Truck size and style?
Intended use?
You do know you will need a standalone control computer, to control the operation of the trans...
DO you just want an overdrive trans?
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 09-24-2019, 09:12 AM   #3
bigmac73
bigmac73's Avatar
Re: 4l80e infi
i understand the stand alone controller I have been looking at these off and on for a while now. Yes i want an overdrive but something that will stand up behind a big cube small block stroker.
I am not concerned with the modifications as i have done several different tranny swaps in my lifetime, how ever i am concerned with the reliability and functionality i guess. I get mixed reviews on the controllers etc etc...
Mike
Old 09-24-2019, 09:38 AM   #4
davepl
davepl's Avatar
Re: 4l80e infi
Love mine except the speedo drive. Maybe I have the cable bent too sharp somewhere but the needle bounces badly under 40 sometimes.
If I had it to do over again, I'd bit the bullet and buy the $600 tailhousing with the mechanical speedo drive cast into it!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-24-2019, 08:40 PM   #5
AussieinNC
Moderator
AussieinNC's Avatar
Re: 4l80e infi
davepl...I find if I drop out the cable and lube it with gravite based grease the bouncing issue usually goes away...
Hope this helps
2012 Chevy Equinox
Old 09-24-2019, 08:50 PM   #6
AussieinNC
Moderator
AussieinNC's Avatar
Re: 4l80e infi
4L80E is the way to go then...make sure its built correctly and has new solenoid pack installed...dont trust the old one....
Controllers are a mixed bag...
I have had best results so far using...https://www.summitracing.com/parts/tci-302820 which includes the harness...
Hope this helps
2012 Chevy Equinox
