Old 10-04-2019, 09:25 AM   #1
58pan
This ole girl followed me home
55 GMC has some rust but not bad. Runs but has blow by. Just picked up the bed yesterday has a couple of small dents but no rust. Not bad for 800
58pan is offline   Reply With Quote
Old 10-04-2019, 09:28 AM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: This ole girl followed me home
Nice find....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 10-04-2019, 09:30 AM   #3
GOPAPA
GOPAPA's Avatar
Nice find ,,,is it a original dually ? your in Idaho but way north of me . like to see this in person.. keep in touch with your improvements with this diamond in the rough ..
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 10-04-2019, 09:35 AM   #4
notsolo
notsolo's Avatar
Can't wait to see that cleaned up, nice score.
notsolo is offline   Reply With Quote
Old 10-04-2019, 09:39 AM   #5
Getter-Done
Getter-Done's Avatar
I like it.
Great deal.
The early bird gets the worm,
85 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 10-04-2019, 11:51 AM   #6
truckster
truckster's Avatar
She's a beauty. Congratulations.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 10-05-2019, 08:19 AM   #7
FleetsidePaul
R.I.P. E.S.L.L.
FleetsidePaul's Avatar
Nice. I would have snapped that up in a second for 800
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350.
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Every day is a gift from God.
FleetsidePaul is offline   Reply With Quote
Old 10-05-2019, 08:32 AM   #8
68panelman
68panelman's Avatar
Looks solid
68panelman is online now   Reply With Quote
Old 10-05-2019, 09:44 AM   #9
58pan
The rear is not factory. The winch is home make but the guy that built it sure used his noodle. The truck hasn't been licensed since 1975. The guy I got it from only used it a couple of times. For the time being I have to let it sit as winter is around the corner and I have a lot of wood to get in.
Question for all you wenches. I'm looking for a rear end for this thing. What would be a good rear? I'd like to be able to do atlease 65 with it. It's a 3/4 ton.
Old 10-05-2019, 10:21 AM   #10
truckster
truckster's Avatar
Are you asking about ratio or specific rear end units? I like a 3.73 rear as a good general-purpose rear for a truck. It will get you to freeway speeds easily enough.
1995 Camaro Z/28
Old 10-05-2019, 03:49 PM   #11
58pan
I need a complete rear. I was wondering if there was a specific year truck I could the rear from?
Old 10-05-2019, 04:01 PM   #12
Getter-Done
A 14 bolt full-floating rear axle would be your best
choice IMO.
Ratio choices :3.21, 3.42, 3.73, 4.10, 4.56, 4.88, 5.13, and 5.38
https://en.wikipedia.org/wiki/10.5%2...t_Differential
85 Chevy K-20
Old 10-05-2019, 04:34 PM   #13
truckster
truckster's Avatar
I would also recommend a newer model 14 bolt FF.
1995 Camaro Z/28
Old 10-05-2019, 04:51 PM   #14
Getter-Done
^^I agree^^
One change that occurred in the second design was that on some models the brake drum could be removed without having to remove the hub and axle shaft
85 Chevy K-20
Old 10-11-2019, 09:35 AM   #15
58pan
Guys, these 14 bolt ff rear ends that you are talking about. Are 2 wheel drive and 4 wheel drive rear ends the same? And it must be 8 lugs.
I've always been a motorcycle guy this is all new to me. I have lots of dumb questions. Thanks
Old 10-11-2019, 10:54 AM   #16
cornerstone
cornerstone's Avatar
Glad I'm not alone anymore.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 10 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 10-11-2019, 11:21 AM   #17
biketopia
Ask a dumb question, feel dumb for a minute, don't ask a dumb question be dumb forever....
Looks like a nice score!!
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 10-11-2019, 11:50 AM   #18
67ChevyRedneck
67ChevyRedneck's Avatar
I was kinda hoping for a bad wife joke, but this is much better. Cool truck. Definitely don't see many 55-59 GMCs.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-11-2019, 01:34 PM   #19
Getter-Done
Here some of the specs I found with the differences.
Spring perch will probably be the main issue for you.(maybe or Maybe not)
14 Bolt Axle Dimensions
WMS to WMS width
'73-'91
Axle tube diameter
Axle tube thickness
Hub type
Driver axle shaft length
Pass. axle shaft length
Wheel stud threads
Brake type
Pinion centered
SRW
67.5" '89-'00 3.375" 0.5" Outboard 37.625" 31.625" 9/16"-18 Drum Yes
SRW
65" '00-07 3.375" 0.5" Outboard 37.625" 31.625" M14-1.5 Drum Yes
SRW
68" 3.375" 0.5" Outboard 37.625" 31.625" M14-1.5 Disc Yes
DRW
72" 3.5" 0.5" Inboard 9/16"-18 Drum Yes
C&C DRW
63.5" 3.5" 0.5" Inboard 37.625" 31.625" 9/16"-18 Drum Yes
SRW Van
70" 3.5" 0.5" Outboard 39.375" 33.375" 9/16"-18 Drum Yes
14 Bolt Axle Spring Perch Width
Axle
Spring perch spacing
3/4 ton 14 bolt 42.5"
1 ton 14 bolt 40.5"
Info came from this link: https://www.roundforge.com/articles/...rw-drw-and-cc/
85 Chevy K-20
Old 06-25-2020, 09:48 AM   #20
58pan
I found that this truck is worthy of a back yard restoration. The rust is not bad but needs some love. The question I have is where the front motor mounts are there two pieces of channel welded to the frame. Is this right or Mickey and goofy working on it before I got it. Thanks
Old 06-25-2020, 09:57 AM   #21
nvrdone
those mounts look like they were used to install an early style engine with the front motor mounts - the ones that look like a bolt with rubber washers.
Not being really familiar with this era truck, maybe some one can clarify. some one may have done an engine transplant.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's
Bought in 1973 for $235.00. Had it longer than my wife & Kids!!
nvrdone is offline   Reply With Quote
Old 06-25-2020, 10:17 AM   #22
58pan
Here is a better pic.
Old 06-25-2020, 11:44 AM   #23
mr48chev
mr48chev's Avatar
I'm thinking that the mounts show that someone did a quick and nasty engine change in it. That doesn't happen to be a 235 or 261 rather than a GMC engine?
You are going to have to watch the axle width on the back real close to keep the tires under the fenders. I'd check the rear axle to make sure that they didn't just adapt it for the dual rear wheels and leave the 3/4 ton axle. My buddy did that a time or two but he is in a nursing home with dementia and isn't able to tell me how he did it. A real dual wheel rear axle is usually a bit narrower than a single wheel axle. That would let you remove the duals and fit the bed and fenders to it while hunting down the right axle with road gears.
That truck looks pretty good for having a wrecker boom on it. I've seen a few with those home made booms used for yard dogs in wrecking yards that were beat to death but that one must have had a specific task to do in it's life.
My ongoing truck projects:
Old 06-25-2020, 01:01 PM   #24
1project2many
I agree. GMC engines mounted in the center of the crossmsmber. Chevrolet engines have mounts on either side of the crankshaft.
I'd love to see more pictures of the boom and winch. I see a manual crank... is it also powered by PTO? There's a hydraulic brake assembly to slow or stop it... Is that park brake lever connected to a master cylinder? very cool stuff.
For the axle a Dana 60 or 14 bolt corporate axles are both good choices. You may want to look for axles from a cutaway van chassis instead of a truck. I believe they are narrower. Also, the 2003 and newer G vans have a bolt-on spacer that allows a single wheel front end to use wheels for the dually. If the dimensions work out you would be able to run only one type wheel.
These are some axle dimensions for a 98-2002 ish van.
1project2many is offline   Reply With Quote
Old 06-25-2020, 08:38 PM   #25
nvrdone
58 pan - you're lucky you are in Sand Point. There is a guy down the road in Athol that deals in old Chevy truck parts. he's posted on craigslist - Spokane. if you cant find his number, I may still have it.
Looks like a fun project.
