Old 10-20-2019, 11:58 AM   #1
sstock
sstock's Avatar
Front frame crossmember ??
Hello, I'm a new member and just picked up a 64 GMC, noticed that somebody in the past used the front crossmember as a tow point. It has pulled the one side of the crossmember out of the frame rivets and bent it. This is the steel crossmember that is directly under the radiator. Was wondering if this is repopped or do I have to go junk yard shopping to find another?
Thanks in advance Steve
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange
1964 GMC 1000 series,custom, 305E, sm420
sstock is offline   Reply With Quote
Old 10-20-2019, 01:11 PM   #2
65 GMC
Re: Front frame crossmember ??
[QUOTE=sstock;8612871]Hello, I'm a new member and just picked up a 64 GMC, noticed that somebody in the past used the front crossmember as a tow point. It has pulled the one side of the crossmember out of the frame rivets and bent it. This is the steel crossmember that is directly under the radiator. Was wondering if this is repopped or do I have to go junk yard shopping to find another?
Thanks in advance Steve[/QUOTE
As far as I know that is not reproduced. I just changed the same crossmember in my 65 C10, as is also had towing damage. The hardest part is getting the old one out due to the factory rivets. A cutting torch really makes the job easier. I just bolted the replacement one back in.
65 GMC is offline   Reply With Quote
Old 10-20-2019, 01:31 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Contact these guys, Phone them! - https://www.aspenautoaz.com/store/c3...uck_Parts.html
Unless you're looking for an aftermarket unit - https://azproperformance.com/collect...6-c10-6366-001
Old 10-20-2019, 06:21 PM   #4
PGSigns
PGSigns's Avatar
Another option is to become a supporting member of the forum. This will allow you to post both foresale and wanted ads in the parts section. I am sure you can find it here. For getting the old one out I use an air chisel and take the heads off then use the air chisel to drive them out. Once you get the hang of it they come out quickly.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-20-2019, 10:49 PM   #5
sstock
sstock's Avatar
Thank you all for your responses,
Steve
