Old 11-22-2019, 07:55 AM   #1
racerop
racerop's Avatar
Stock air cleaner that would fit Holley carb
I have been looking for an air cleaner
to fit a holly 4-barrel carburetor.
Is there anyone that knows if there are
cars or trucks from any era that would fit?
The one I found was probably for a Rochester
Quadrajet it doesn’t clear the back bowl
I really liked the chrome air cleaner that
came on my truck but isn’t practical for the
lack of attention I give it lol
Thanks for any help in cross referencing any
known part that fits. I’m not using this to
find one I need help on what application
had the larger opening for a 4 barrel that
didn’t use a q-jet
racerop is offline   Reply With Quote
Old 11-22-2019, 08:22 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Stock air cleaner that would fit Holley carb
Look at the Camaro z-28 / Chevelles air cleaners those 2 come to mind They won't be cheap, maybe find an ebay special .
need more coffee
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 11-22-2019, 10:49 AM   #3
geezer#99
geezer#99's Avatar
Raise the air cleaner base using a spacer.
Like these.
https://www.amazon.ca/Spectre-Perfor...70178009&psc=1
geezer#99 is online now   Reply With Quote
Old 11-22-2019, 11:15 AM   #4
kwmech
Yep--spacer, I used a later model (factory steel one about 1'' thick) with TBI that has the hose fitting on it for the PCV vent
Old 11-22-2019, 12:35 PM   #5
You just need a spacer. Why not run an open element if you like those? Some of those end up needing a spacer, too. I run a Moroso open element on top of the factory spacer, so still use the factory crankcase breather. This is with a QuadraJet. I think the base didn't fit the carb. I also like the venturi affect of the taller spacer
Old 11-22-2019, 12:47 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Here's one on the parts board.
http://67-72chevytrucks.com/vboard/s...ht=carb+spacer
I think there are different height ones too.
LockDoc
Leon
Old 11-22-2019, 04:46 PM   #7
Mike C
Mike C's Avatar
I bought a 70 Z/28 air cleaner to run on my L36 427 for my short step. It is a dual snorkel that uses a 14x3 hi-perf air filter the same as the OEM open element air filters. $190 or so on Rock Auto.
67-69 Z/28 air cleaner is the best drop base open element Holley air filter. Provide max hood clearance or let you run max air filter size. Around $80.
Both are designed for factory dual inlet holley carb applications.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-22-2019, 09:50 PM   #8
firedemon
some first gen Camaro came factory with a holley spreadbore I think they were dual snorkel
firedemon is offline   Reply With Quote
Old 11-22-2019, 11:05 PM   #9
Mike C
Mike C's Avatar
67-69 Z/28's and L78 Camaros had square bore holleys, but they used open element air filters as I said above. The 70-72 Z/28 and I THINK the 402 in same years had the dual snorkel.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 11-22-2019, 11:23 PM   #10
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Stock air cleaner that would fit Holley carb
I use a open with 2" spacer on my 64 SS Impala. I have a 4 barrel Edelbrock Carburetor on it. Works great.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
