Old 11-24-2019, 02:40 PM   #1
phlegm
Still Green but learning
phlegm's Avatar
Fuel Pump Change - return bypass?
Hi guys. So I recently had my Qjet rebuilt and replaced the old gas tank (rust and crud) and sending unit. Still getting rust in the fuel filter, so I ordered gas lines (tank to carb) the other day. I am figuring I may as well replace the fuel pump while I am at it.
Here is my question, should I simply get the 2 port Fuel Pump and cap off the return line at the tank? or purchase the 3 port pump and use carb cleaner and compressed air to blow that return line out?
Any experience out there in either direction? Thanks in advance, as always.
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 11-24-2019, 09:11 PM   #2
phlegm
phlegm's Avatar
Re: Fuel Pump Change - return bypass?
Nvmd found answer upon further review. Some carbs can be pressure sensitive, so not knowing if mine is one... just gonna replace with a 3 port fuel pump and clean the line.
thx
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
