Junior Member
D49 Sport Mirror Brackets
I'm having a heck of a time finding just the mounting bracket and gasket for the little sport mirrors for our trucks. I read on a post that they were the same as a 69 Camaro so I ordered kits from Summit. No go. Anybody have a source for just the brackets that is certain to fit? Part number on the arm is 9826594. This comes up for 73 Chevelle (and others depending on which site you're lookin at) . Looks like they had different mirror heads but the same base. however cannot find just the mounting kit. help!
Title for this assembly would indicate it would work but pic does not reflect that for sure. https://www.ss396.com/chevelle/MHQ-7377.html 79 Silverado posted a great pic of the entire mounting assembly about 6 years ago. (shown)
"I was patina when patina wasn't cool." 1973 Cheyenne Super SWB Sunset Gold / Frost White / Saddle |
![]() Join Date: Jun 2009
Re: D49 Sport Mirror Brackets
Do you already have the inner support bracket? Black metal piece in the last picture?
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
Junior Member
no I just have two mirrors and that's okay I think it would be fine without the black inner bracket anyway
Mine seemed to shake a lot more without them. Also, you are less likely to have the screws pull through the door if you use them
Junior Member
Yeah if a kit came with the inner brackets I'd install them but if I just found the outer brackets I'd call it good
I would see if you can come up with used brackets before buying new. The reproductions are thin and IMHO don't compare to OEM. I think the gaskets are the hardest to come by.
Junior Member
I'm open to either. Cannot find.
Junior Member
Bracket (Retainer) is GM #9826886 and gasket is GM #9829666
Junior Member
Maybe found some brackets here:
http://www.pontiacparts.net/Body/page39.htm No pix tho, and for $40 might as well get a whole new kit and sell mine as 69 camaro mirrors.
#10 | |
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
Junior Member
Thanks Bandit! LMK
This is what I dug up that I have left. I believe I used the black plates when installing new mirrors. These are the originals that I removed. These will work without the black plate that is on the inner door. But , I would find some type of plate and drill holes then use small bolts with washer, lock washer and nut to secure to the door skin. I think that if you only use metal screws into door they may loosen over time and will not hold securely. If you want these, PM me and I will only take shipping for them cause I don't think I would ever use them again.
#13 | |
Junior Member
| Bookmarks |
