Old 12-29-2019, 01:16 PM   #1
63gm
Squaring up cab
Looking for suggestions for squaring up the cab prior to assembly
63gm is offline   Reply With Quote
Old 12-29-2019, 02:26 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Squaring up cab
On the frame? Or the sheet metal itself?
Old 12-29-2019, 03:19 PM   #3
63gm
The sheet metal itself I have it sitting pretty close to square on the frame now
Old 12-29-2019, 03:26 PM   #4
63gm
I don’t have any of the cab support welded in or the firewall obviously I wondered if I should put the doors on and the front clip on then square that all up before I weld anything together just looking for other suggestions or if anyone thought that is a good plan
Old 12-30-2019, 10:29 PM   #5
Robert Haas
Re: Squaring up cab
Since the doors are adjustable they can be hung and the cab can still be tweaked.
If the frame is spot on you could level and confirm the chassis is square, then mount the body rigid to the frame without the rubber isolators and confirm the bolts are centered in the bores of the cab and the frame. (will need to build some sleeves. Simple job if you have access to a lathe) Once frame is bolted and aligned with the chassis you could then hang and gap the doors. once they are perfect weld in the firewall. and you should be golden.
Our 1965 GMC big block pro mod build http://67-72chevytrucks.com/vboard/s...d.php?t=746098
Robert Haas is offline   Reply With Quote
Old 12-31-2019, 12:24 PM   #6
63gm
Thank you rob I think that’s what I will do
