Old 12-30-2019, 03:24 PM   #1
67bullet
which front brake calipers
I installed a ssbc 6 lug disc brake conversion kit # a126-71 on my 67 swb,I have replaced almost every component in the system twice,I have bleed the brakes a hundred times.I finally put a 72 master cylinder which I bleed twice, and a dual diaphragm 8 inch booster from summits on it.It will stop ok but it will not lock up the brakes.every part in the rear brakes is new,It has an adjustable proportioning valve,So I am looking for a set of calipers.The instructions says it takes D-368 brake pads.The center to center bolts on the calipers,look to be 5 3/4 of an inch I just crawled under the truck and did not remove the wheels.any info would be appreciated.this engine has 22 inches of vacuum.Thanks Jeff
67bullet is offline   Reply With Quote
Old 12-31-2019, 09:53 AM   #2
67bullet
Re: which front brake calipers
Anyone know what calipers may fit this setup
Old 12-31-2019, 10:25 AM   #3
dennislbrooks
dennislbrooks's Avatar
As far as more standard sizes for calipers I have found 7.00", 5.50", and 5.25, and 3.25 for caliper mount centers.
You might take a look at speedway disc brake brackets for an idea or maybe call your kit supplier.
I would expect rears to lockup before front, maybe more rear pressure, maybe too much traction.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 12-31-2019, 11:09 AM   #4
67bullet
ssbc has gone under,out of buisness
Old 12-31-2019, 11:11 AM   #5
67bullet
thanks dennislbrooks for the reply
Old 12-31-2019, 11:48 AM   #6
dennislbrooks
I take you have disc/drum and not disc/disc. And were referring to the front calipers?
Old 12-31-2019, 11:53 AM   #7
dennislbrooks
1991 Chevrolet C1500 and others -- look on ebay for D-368 brake pads and what they say they are for. Not sure if they are the calipers.
If correct, Rockauto shows many calipers for the c1500 -- looks like metric.
Old 12-31-2019, 01:51 PM   #8
67bullet
yes they are disc/drum and yes its the front calipers
Old 01-02-2020, 06:55 PM   #9
67bullet
This brake conversion says to be the same as a 1991 k 1500 with standard chassis,ok does anyone know where I can find a set of larger calipers, centerline measurement on bolts 5.750 or a disc brake bracket to fit 6 lug stock spindale for a 67 and the aftermarket calipers.Thanks Jeff
Old 01-02-2020, 07:29 PM   #10
mgchevyparts
mgchevyparts's Avatar
Your calipers are 1988-91 Chevy/GMC 1500 light duty (not extended cab) 2.5" piston
4301/4302 are common part numbers for the calipers.
You can't just change calipers without making at minimum new brackets, essentially you need to re-design an entire kit.
Those calipers are plenty adequate for your truck. You have a problem in the hydraulic delivery, AKA master-booster-possibly your plumbing or AIR in system
You should be using a 1 1/8" bore master, although a 1" will also work but with too much pedal travel.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 01-02-2020, 07:55 PM   #11
67bullet
Ok thanks MGCHEVYPARTS
Old 01-02-2020, 07:58 PM   #12
mgchevyparts
What size tires are you running?
Old 01-02-2020, 08:03 PM   #13
67bullet
Fronts are 245 60 x 15/rears are 275 60 x 15.mickey Thompson s/t all around
Old 01-02-2020, 08:36 PM   #14
mgchevyparts
Ok, I was concerned you might have the big 33" tires, those kill braking power.
