Old 01-03-2020, 03:02 PM   #1
bry593
LQ4 '71 C20 Engine Mount Question
I recently installed a 2001 4L80E behind a Gen 1 sbc in my C20. That means my driveline, shift linkage, etc is all setup for the stock bellhousing location. Will an LQ4 clear the firewall in the stock Gen 1 bellhousing location? If so, can anyone recommend a vendor for the appropriate motor adapter plates? I would also like to maintain the crankshaft centerline, meaning I don't want to raise or lower the engine too much or this will affect my shift linkage and possibly driveline phase angle.
I appreciate the advice!
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs
bry593 is offline   Reply With Quote
Old 01-03-2020, 03:17 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: LQ4 '71 C20 Engine Mount Question
Although mines a C30 I used the Ebay adapter plates that locate the rear of the LS in the same location as a small block...theres plenty of room between engine and firewall on mine...I dont know about your c20 though..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-03-2020, 11:19 PM   #3
Captainfab
60-66 Nut
I don't see why there would be any difference between a C20 and a C30.
Old 01-31-2020, 01:23 AM   #4
Factory Guy
Factory Guy's Avatar
The "tejas" mounts keep everything as close to stock as possible AND allow you to keep the factory AC compressor and in its original down low position (without cutting the frame!)
Factory Guy is offline   Reply With Quote
Old 02-01-2020, 09:52 PM   #5
v30crewcab
v30crewcab's Avatar
any pics of the tejas mounts? do they work on a 71?
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
