Old 01-21-2020, 09:46 PM   #1
Acavet
Chevy and BOP transmissions
I recently purchased a nice 4x4 frame that came with a TH350 trans. The trans of course was intended to hook to a transfer case. I intend to run a solid axle front end without the differential. I’m having trouble locating a tail cone for the trans but ran across a cheap B.O.P 350. My question is would the tail cone and shaft fit my Chevy transmission?
Acavet is offline   Reply With Quote
Old 01-21-2020, 11:02 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Chevy and BOP transmissions
welcome..
i have no idea what a b.o.p. trans or engine is...but you have to have a 2wd output shaft as well ...be much easier to just find a 2wd trans...especially if you don't know the condition of what you have...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-21-2020, 11:14 PM   #3
v30crewcab
v30crewcab's Avatar
only difference in the bop is the bellhousing. but you have to take the trans completely apart to change the tailshaft to a 2wd one.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 01-21-2020, 11:21 PM   #4
v30crewcab
v30crewcab's Avatar
bop=buick olds pontiac bellhousing pattern.
71 longbed 5.3 4l80
Old 01-21-2020, 11:24 PM   #5
mongocanfly
gotcha...never heard of bop before
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-22-2020, 07:47 AM   #6
Keith Seymore
Keith Seymore's Avatar
Pronounced "Bee Oh Pee" if you ever have the opportunity.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-22-2020, 08:57 AM   #7
Mike C
Mike C's Avatar
4x4 trans has a shorter main shaft than a 2x4. You can’t just add the tailhousing and make it work.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-22-2020, 10:57 AM   #8
GRADYS Performance
GRADYS Performance's Avatar
If the BOP TH350 trans is a 2WD model the tailhousing and output shaft will fit your Chevy TH350. The transmission will have to be taken apart to change the output shaft because it is held internally by a snap ring. You could just use the BOP trans with a TCI Adapter Plate as the dowel pins and 2 of the bolt holes are the same between the 2 cases. Send Me a PM if you have any questions.
GRADYS Performance is offline   Reply With Quote
Old 01-22-2020, 01:11 PM   #9
Acavet
Thank you....The transmission that came with the frame is supposedly rebuilt. I was not aware that the transmission needed to be disassembled to have a longer shaft installed. I thought the tail shaft was independent of the rest of the transmission.
I guess I’ll just sell the trans I have and buy another. I’d prefer a 400 any way.
Old 01-22-2020, 02:09 PM   #10
mongocanfly
Thanks Keith..!!!...haha
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-22-2020, 02:11 PM   #11
GRADYS Performance
A TH400 will take a different yoke and mount than the TH350.
