Old 02-03-2020, 10:40 AM   #1
phlegm
Still Green but learning
phlegm's Avatar
Manual Fuel pump install 67-72 C10
PSA for any other amateurs stumbling on this in a google search... When youtube and the rest of the interweb say lift the pin, what they really mean is PUSH the pin up into the block.
That is all....
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 02-03-2020, 11:21 AM   #2
dmjlambert
dmjlambert's Avatar
Re: Manual Fuel pump install 67-72 C10
Yes, and almost nobody mentions the short bolt in the front of the engine that lines up with the push rod. I remove it and put in a longer bolt that can snug up against the rod to hold the rod in the up position. Then, when done installing the fuel pump remove the longer bolt and re-install the short bolt. Shown here by forum member Longhorn Man in this thread:
dmjlambert is offline   Reply With Quote
Old 02-03-2020, 11:35 AM   #3
phlegm
phlegm's Avatar
yea, i found that in the same thread that finally told me to push the rod up. I used one of the longer front bolts. I put the left long in the front but didnt tighten it all the way down. held pump in place with my hand, removed the other from the side and moved it to the front. Saved me 40min round trip to the Hardware store.
remember to put RTV on the short bolt when you put it back on to prevent oil leaks.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 02-03-2020, 11:47 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I spent a lot of time frustrated while trying to install a fuel pump before I learned about that bolt here on this board. Sure makes the job easier!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
