Using rubber hose for an Trans oil cooler.
Is it ok to use rubber lines for oil coolers? or braided metal tubing?
http://s1299.photobucket.com/user/jb...23904108567829 Last edited by jbgroby; 02-28-2020 at 03:07 PM. |
It's Better With Nitro
Re: Using rubber holes for an Trans oil cooler
I usually use a minimum 300 psi-rated hydraulic hose, or hardlines.
this is typical of what you'll find in auto parts stores or can order online if you know the diameter and lengths you need..
TRANSMISSION OIL COOLER HOSE hardline tubing is much hardier but requires a little more time and skill.. or can use a combination of both, really depends on application.. good luck!
I started out with nothing - and I still have most of it |
![]() Join Date: Aug 2008
I used braided with AN fittings.
| Bookmarks |
