![]() Join Date: Dec 2003
Anyone running a quick release steering wheel?
I'm going this route and was wondering if anyone else has done this as well.... I just purchased the NRG short hub and quick release... i'm still trying to decide what steering wheel i wanna go with... (without breaking the bank)
Anyone??
https://www.ebay.com/itm/295742064443 |
Re: Anyone running a quick release steering wheel?
Interested in replies.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
How do those hubs work...can you use any wheel or does it take a special one? -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
I had one years ago on a '71 Chevelle daily driver. It was no problem; just be sure to pull on it, every time after it's off & back on, to ensure it's locked in.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
had one in a fixed seat / fixed column race truck, pert near impossible to get in there without it
![]() not sure where else it would be useful ![]()
I started out with nothing - and I still have most of it |
Post Whore
![]() Join Date: Feb 2016
Theft deterrent?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Yes, Theft deterrent, would be nice to remove to work under the dash at times... and just the cool factor.
I think you can get quite a few different wheels, i think they have the same industry standard bolt patterns.
I can't steel this car without a steering wheel - said no thief ever..
in jest, but short of maybe crack heads or passing teenagers, not a solid security plan.. good luck!
Hard to stop a ramp truck. But you can steal one of these trucks with a short piece of wire with alligator clips and a screw driver! Wouldn't hurt?
in the context of stopping a 'driveoff' thief, I would place my efforts elsewhere..
beating thieves in a lot of cases is accomplished by slowing them down.. I'll concede, it's better than nothing.. and cool too if that's your gig, I got tired of it..
you can use a vice grip to steer, don't need no stinking wheel
#13 |
Agreed...if someone is planning on taking my truck it's gonna be gone probably no matter what I do. I'm thinking more about the impulse thief! No wheel, no deal. -klb
#14 |
![]() Join Date: Nov 2015
I like it , probably look into installing one on my truck for the cool factor alone, if it helps in the theft department so be it!
Just need to make sure what ever wheel I install doesn’t interfere with the turn signal lever. Current wheel installed by PO is terrible, hand seems to always contact the signal lever :cuss
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB. Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project |
#15 |
#17 |
![]() Join Date: Nov 2012
I have one in my car,I have a momo steering wheel, the key is getting the right hub adapter for your steering wheel. Don't forget to compensate for the height of the adapter when anything other than a flat wheel.
#18 |
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
Don't even need the screwdriver if it's a manual transmission
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
