Old 03-16-2020, 01:27 PM   #1
Minkota
Door Binding
My driver side door on the 67 will occasionally bind and not open past half way and I will have to partially close it and reopen it a few times before the binding stops and the door will open all the way. I do not see anything obvious wrong with the hinge that would be causing this. is this a common issue, what is the issue is it the Hinge?
Minkota is offline   Reply With Quote
Old 03-16-2020, 01:34 PM   #2
Sheepdip
Sheepdip's Avatar
Re: Door Binding
I'd start with some good silicone spray lube then observe from there.
Sheepdip is offline   Reply With Quote
Old 03-16-2020, 02:25 PM   #3
Willys_MB
Willys_MB's Avatar
Re: Door Binding
You might need new pins/bushings for the door hinges. They're relatively cheap or if you're an NOS guy there are some for sale on the parts board. You just need a vise, vice grips, and a hammer to get them out. Or if you have access to a press it'll take a couple of minutes.
Also check the adjacent body panels. My passenger door binds up on the front fender, but I haven't had a chance to loosen bolts and make adjustments yet.
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 03-16-2020, 02:35 PM   #4
67mater
67mater's Avatar
Re: Door Binding
what shape are the door stop pads and arm in? they are in the middle of the upper hinge. also, the door isnt catching the fender is it?
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 03-17-2020, 01:29 PM   #5
Minkota
Re: Door Binding
I will post a pic later this evening or tomorrow. it is not catching on the fender.
Old 03-17-2020, 01:57 PM   #6
rsgt
rsgt's Avatar
Re: Door Binding
Check also for cracks in the door frame around the hinges.
rsgt is offline   Reply With Quote
Old 03-18-2020, 07:08 AM   #7
Minkota
Re: Door Binding
When I try to upload pics i get this message
"Your submission could not be processed because a security token was missing.
If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error."
Is this an issue on my end?
Old 03-18-2020, 07:34 AM   #8
AussieinNC
Moderator
AussieinNC's Avatar
Re: Door Binding
The attachment you are trying to upload is too large, reduce it is size to below the listed file sizes on the upload panel
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 03-18-2020, 07:54 AM   #9
Minkota
Re: Door Binding
I am not seeing anything too obvious. maybe one of you more experienced with the hinges can spot something.
Old 03-20-2020, 06:24 AM   #10
Minkota
Re: Door Binding
Any other suggestions?
Old 03-20-2020, 10:13 AM   #11
sick472
sick472's Avatar
Re: Door Binding
Pull the inner door panel and take a look-see to make sure something out of place is not hitting the portion that goes into the door. Make sure that same piece in not catching on the hole that it goes into. Other than that, you may have a broken pin. Willy eluded to this above.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 03-20-2020, 11:43 AM   #12
Thealien
Thealien's Avatar
Re: Door Binding
In post #9 in the top picture it looks like the stop pads are missing?
Old 03-21-2020, 09:42 AM   #13
chevy71super
Re: Door Binding
Looking at the same picture it appears the slider (that goes inside the door) is hitting something evidenced by the small flat spot on the corner towards the camera. (You can see the slider missing paint where it’s contacting something.) I suggest lubing the whole hinge, hit the flattened spot with a small file to round it and see if that fixes it. I always try the easiest thing first before tearing too deep into what ever the problem is.
71 Cheyenne Super 4X4 SB
72 Cheyenne Super 4X4 SB
72 Cheyenne 4X4 SB
chevy71super is offline   Reply With Quote
Old 03-21-2020, 12:18 PM   #14
67mater
67mater's Avatar
Re: Door Binding
the pads for the stop arm are definitely missing and that's allowing the arm to bind. to my knowledge, the hinge must be taken apart to install new pads. I can get a picture if you need one.
1967 K10
1967 Camaro
Old 03-24-2020, 08:32 AM   #15
Minkota
Re: Door Binding
What does it look like?
Old 03-24-2020, 09:19 AM   #16
67mater
67mater's Avatar
Re: Door Binding
not the best pictures, but here's both sides. the are steel backed pads that bind as the door opens to slow down the door as you reach the end of the arm.
1967 K10
1967 Camaro
Old 03-24-2020, 09:33 AM   #17
Minkota
Re: Door Binding
are those available separately or do I need to purchase the whole hinge?
Old 03-24-2020, 09:38 AM   #18
67mater
67mater's Avatar
Re: Door Binding
You can buy just the pads. Like $13 or they might be in the bottom of your door!
1967 K10
1967 Camaro
Old 03-24-2020, 09:41 AM   #19
Minkota
Re: Door Binding
I will check in the door and if not I will purchase them. where is the best place to get them, GMC Paul? thanks for all the help.
