Old 04-13-2020, 10:51 PM   #1
srfinatsunset
srfinatsunset's Avatar
Horn has power no sound
I replaced the Turn Signal Switch in the the steering column. It’s a non-tilt column. Broken turn signal, original plastic. I plugged everything in and now there is no sound from the horn. I check the power at the horn. 12 Volts when I press the horn button. My horn work before I replaced the switch. Did I burn up the horn? Is the horn 6volt?
srfinatsunset is offline   Reply With Quote
