Old 04-14-2020, 09:07 PM   #1
Ford Assassin
Ford Assassin's Avatar
Question Do I need to pull the steering wheel to change the turn signal arm?
Need to replace a turn signal arm on a mid '80's C10 column. Chrome is peeling the the black is sun bleached gray. Plus I have a Dakota cruise control kit that uses its own dash mounted switch, so I would replace the arm with the version without cruise control.
I read in a search that the wheel doesn't need to be removed, but that thread was 16 years old, so all the pics were gone and most of the folks replying haven't been active in years.
Thanks!!
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
