1966 Inner fender grommets?
I think that the grommet to the firewall is needed but Im confused on if I have the right part.
I have a pic of the inner fender after I pulled it, looks like it had a rubber grommet. Ill also add a pic from the installation manual. The part at Classic looks like this https://www.classicparts.com/1960-66...ctinfo/37-852/ Then I saw this part on Brothers but its just a bolt. https://www.brotherstrucks.com/1960-...tinfo/FSMB66C/ Does it matter which to use? |
Moderator
![]() ![]() Join Date: Aug 2011
Re: 1966 Inner fender grommets?
Oh wow, thats a toughy.
It uses both. I went back to my pictures and know the bolts have distinctive undercoat
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
Im being unsmart about this I guess. The hole needs a grommet and the bolt goes through the grommet. I didnt see the grommet part in the Truck Shop catalog yesterday when I placed my order. I guess its Classic Parts then.
Thanks for the confirmation! I posted just after you did.
| Bookmarks |
