Old 04-25-2020, 11:08 PM   #1
wbmoore
Center Console question ???
Hey...
I have a junkyard center console. It’s probably out of a Suburban...can’t remember. When I pulled it, I pulled the rear bracket with it. Maybe I couldn’t get the front one. Again, can’t remember.
The question is: should this console also have a bracket for the front. Or, if it is from a Suburban or Blazer, are their floor pans different so it didn’t need one in the front ?
If anyone knows the answer...lemme know.
Also, if it does take a front bracket....does anyone have a spare ?
Thanks.
1967 GMC 3500 lwb dump flatbed project
1969 GMC 2500
1979 GMC 7000 fire crew truck w/water pumps
1982 C/30 Cummins NV5600 Crew Cab project
wbmoore is offline   Reply With Quote
Old 04-27-2020, 05:25 PM   #2
Re: Center Console question ???
I have one like that from a Suburban and I don't have a front mount either. Floors are different between trucks and Burbs/Blazers. They just screw onto the floor in the Burbs/Blazers. This came out of my service manual for my 81, so maybe it will help.
Palf70Step is online now   Reply With Quote
Old 04-28-2020, 01:05 AM   #3
Too Tall
I scoped one out of Burb as well.
The back just screwed to the floor in my pick up.
It bolted down just like the Burb.
1981 GMC
Too Tall is offline   Reply With Quote
Old 04-28-2020, 11:03 AM   #4
burb1085
burb1085's Avatar
So the rear bracket is not used on the pick up? Only the Suburban?
burb1085 is offline   Reply With Quote
Old 04-28-2020, 11:04 AM   #5
burb1085
burb1085's Avatar
Is the older style console (73-80) the same way ? ��
Old 04-28-2020, 02:42 PM   #6
hatzie
Moderator
hatzie's Avatar
You can likely find the full parts blowup in the parts manuals.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-29-2020, 02:23 PM   #7
SCOTI
SCOTI's Avatar
No specific answer as to what exact part was used from the GM factory but I yanked some buckets & the console (like pictured above) from an 89 Burb to swap over to my 89 CC dually.
After looking over the later style console it seemed 'cheap' compared to the earlier Squarebody versions so I found & used an earlier console w/the 89 seats. I used the factory 'Z' (stepped) mounting bracket from the Burb for the rear of the console. That required bolting the bracket to the console & then marking & drilling mounting holes in the floor.
The later console had no front bracket but the earlier unit would not sit as desired w/o something under it. To properly space it for level, I used 1" square .125 wall tube as a spacer. I put rivet-nuts in the floor pan, drilled oversized holes through the tube 'spacer', & used some extended length bolts to secure it in place. The spacers (front & rear) are hidden under the carpet & not visible.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
