Old 04-27-2020, 12:24 AM   #1
Guardrail
And Don't Call Me Shirley
Guardrail's Avatar
Smile Cart for Transporting Cab for Rust Repair
Hello,
I'm about to embark on a complete restoration of a '72 K-10 LB and I'm wondering if there might be someone out there in Northern California who has some sort of a cart they used during the restoration of their 67-72 to hold/transport the cab. Perhaps you built one and its just sitting around in your way. If you have one and I could purchase it or even lease if think you might need it again.
That brings me to another question. Does anyone here know someone close to Sacramento that could blast my cab, then install rockers and other minor rust repair at a fair price? I'm looking for someone that has experience with these trucks.
Thanks In Advance,
Rick
Rick Tucker
1969 C20/Custom Camper (the Green Machine)Sold
1970 GMC 4000 COE (future Ramp Truck)
1972 K10 Longbed (restoration begins June 2020)
Guardrail is offline   Reply With Quote
Old 04-27-2020, 12:28 AM   #2
toolboxchev
Re: Cart for Transporting Cab for Rust Repair
Could not tell which member, but do a search, someone has drawn up plans for others to use.
Sharing is nice!
toolboxchev is offline   Reply With Quote
Old 04-27-2020, 12:33 AM   #3
dirtyd_nd
For the transport I just run lag bolts though the cab mounts into a 4x4 then get some casters from harbor freight to roll it around on. If you wanted it higher I’m sure you could build a frame to prop it up some too.
dirtyd_nd is offline   Reply With Quote
Old 04-27-2020, 02:03 AM   #4
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
That's a GREAT idea.
For what it's worth I have plans for a well overbuilt wooden cart in my build thread. Only thing I think I'd do differently is a wider wheel base.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-27-2020, 07:36 PM   #5
Tims71step
I had mine on a pallet, bolted some big casters on it and it worked out pretty well.
Tims71step is offline   Reply With Quote
Old 04-28-2020, 04:32 AM   #6
Metaldoc
Metaldoc's Avatar
Bolted through the body mount holes. I did all my sheet metal work bolted to the frame and then removed it for body work. This keeps the body square,
Do it, Do it right, Do it right the first time
Metaldoc is offline   Reply With Quote
