Center Cap options for Rally wheels
Hello,
I have a 1966C10 with disc brakes with Chevy Rally wheels. I bought the rally wheel clips that were sold on eBay. What are my center cap options? I have the following set, which I believe are called Disc Brake Centers, but they do not fit due to the hub on the front rotor: https://shop.wheelacc.com/vintage-ra...14s-p6346.aspx Do the Police caps work? I know the Sombrero work, but not sure I want to go that route. Thank you. Tom Jenkins |
Re: Center Cap options for Rally wheels
I have the Police caps on my rally wheels and they fit but my wheels might be different than yours. I know that is a rear wheel photo but the fronts are the same.
Wheel Vintiques used to sell earlier Chevy caps that would retro-fit onto the 'corvette ralley' styled wheels. I think/recall '36, '49 & '52 caps were available (that fit like the derby caps) but you would have to verify to be sure. I purchased some that have been sitting in a box on a shelf for several (several
) years.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-07-2020 at 09:49 AM. |
This is the wheel I am running. The wheel to end of dust cap is around 2 5/8".
Thank you. Tom |
Measurement...
It really hard for me to tell The way that the Police caps attach to my wheels is allot different than using the clips
#8 | |
You need to know the distance from the end of the spindle cap/seal to the center of the clip since that's where the caps will seat.
Here is the best photo I can find. The red arrows are pointing at the nubs that keep the caps in place. You can see that they are much further out than your clips. I think that the disk brake caps don't fit for the same reason.
Thank you. Yours are different. I think I need to be further out somehow
#11 | |
Yes. I'll grab the caps off the shelf & see what the depth is.
#13 |
One set was about 2" (#1004). The 2nd was deeper (#1017 @ 2.25 - 2.5/2.675").
I tried both of these cap styles w/those same SS clips you're using. This was on truck/van ralleys that were on my 90 & there was no interference. But, a 90 possibly has a different spindle hub/rotor height so earlier trucks could be taller which would yield less clearance. Look through Wheel Vintiques catalog 'accessories' section for cap options.
#14 |
I don’t mean to be negative but I don’t think you are going to find a police style cap that will work with that wheel.
| Bookmarks |
