05-18-2020, 11:57 AM | #1 |
Did you drill to clearance the eyelet on your Bell Tech Shock 2208AA
I have a 1968 Chevy C10 and ordered a set of Bell Tech Shocks. The rear shocks 2208AA only have a 1/2 in eyelet hole and will not fit the 5/8 in lower shock stud that is on the rear.
I measured the front upper shock stud and it also measured 5/8 in. For those that have purchased Bell Tech Shocks what shock did you run on the rear and did you have to clearance the eye of the shock? |
05-18-2020, 03:22 PM | #2 | |
Re: Did you drill to clearance the eyelet on your Bell Tech Shock 2208AA
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power Last edited by ga-stepside; 05-18-2020 at 03:33 PM. |
05-18-2020, 03:41 PM | #3 |
I still have the stock rear shock mounts so I measured the holes for the shocks. There were no studs on the mounts, just bolts and nuts. They are 1/2" both top and bottom. Granted I have no clue if anything on this truck is 1967 including the frame. The mounts were riveted to the frame so I assume they were stock I wonder if someone drilled the mounts to use a non-stock shock on your truck.
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
