05-19-2020, 01:00 AM | #1 |
Intake and exhaust manifold
Hi!
Just got me a 69 C10 with original 6 inline. My plan is to keep it that way. One of the issues is the intake and exhaust manifold, it’s not in good shape. Are those parts still on the market (original) or is there any compatible parts that’s better to look for? I might consider to replace the Rochester carb for a 2 barrel Holley. |
05-19-2020, 01:50 AM | #2 |
Re: Intake and exhaust manifold
There are high performance parts for the Chevy L6s. Check out the following:
www.inlinersinternational.org www.12Bolt.com www.cliffordperformance.com Good luck.
05-19-2020, 08:32 AM | #3 |
Are yours leaking? Pitted cast iron manifolds can be pretty cruddy & ugly and still be functional. They are thick castings. If they're leaking at the gaskets you can dress up the flanges & install new gaskets. Be VERY careful not to wring off bolts & studs disassembling old rusty(like yours) manifolds. Penetrating oil, maybe a little torch heat & tapping them sharply with a hammer helps break 'em loose. If yours are not salvageable check for used parts on this site's classified section. They rust & crack sometimes but they don't wear out. I hate to think how many 6cyl. iron manifolds have gone to scrap......
.... OR there's the hi-perf. after market items like 68OrangeSunshine suggested.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
05-19-2020, 08:36 AM | #4 |
I am seeing some pitting in your photos. Is that all that you are refering to when you say they are not in good shape? Cracks and warps are what make manifolds "not good".
I would not hesitate to sand blast those and reuse after removing and inspecting those areas for good thickness and checking the mating surfacces for flatness. If you are concerned about the appearance alone...get some new ones if available.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
05-19-2020, 08:52 AM | #5 |
When I replaced the manifold gasket on my ‘67 a few years ago (the manifold had never been off the truck - it has a good bit or rust on it too), I sprayed the bolts and nuts down with Aerokroil two or three times a day for three days...and didn’t break anything! I’ve heard that removing a bolt that breaks inside the hole is a real PITA....
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense |
05-19-2020, 10:17 AM | #6 | |
05-19-2020, 10:18 AM | #7 | |
05-19-2020, 10:25 AM | #8 | |
spring doesn’t have any purpose |
05-19-2020, 10:48 AM | #9 |
Is the end of the EX manifold broken?
There should not be a bolt in the end holes of the manifold. There should be only a short locator stud in end holes in the head at both ends. The locator studs are threaded into the head and can be replaced with longer threaded studs when using aftermarket thin tube headers, but not with stock cast manifolds. The 3rd hole in, from both ends of the head were originally 1 7/8" threaded studs with nut. Picture is borrowed from this forum.
'67 GMC 2500, 292, 4spd, AC |
05-19-2020, 10:52 AM | #10 |
Ok. I will take a deeper look at it 👍
05-19-2020, 12:15 PM | #11 |
Richard...you've got good eyes!
