05-24-2020, 09:12 PM | #1 |
Trans question
I have a 67 C10 longbed that I swapped a 5.3 and 4l60e into. The trans needs rebuilt and I found one with no issues locally. My question is that it is out of a 98 and my motor/trans came out of an 01 suburban...will I run into any issues or will it work?
05-25-2020, 09:35 PM | #2 |
Re: Trans question
I would go over to the LS1tech website and ask your question in the transmission section. Those guys are good.
05-28-2020, 01:45 PM | #3 | |
Re: Trans question
I agree with double checking, but you should be good. I believe the electronics stayed the same. There are a few minor differences with regards to the valvebody plates, but I don't believe that will effect you. |
05-28-2020, 06:24 PM | #4 | |
Moderator
Re: Trans question
Between 98 to 01 there were some internal strength upgrades and also, installing a used trans is always a risk. The original trans may well be a 4L65E with upgraded internals as it originated from a Suburban,,,,,
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
05-29-2020, 02:29 AM | #5 | |
Re: Trans question
05-29-2020, 07:44 AM | #6 | |
Moderator
Re: Trans question
They list rebuilt trans units from $899 ... Hope this helps...
05-29-2020, 11:39 AM | #7 |
Re: Trans question
You can get a rebuilt 4L60 from LSX4U for a lot cheaper than $2700. I have a 4L80 from them and no issues so far (only a few short test drives). You could opt for the improved 4L65 or their 4L65-HD (not listed on their website, but available).
http://lsx4u.com/
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
06-15-2020, 11:20 PM | #8 |
Re: Trans question
rebuild it yourself
