Old 05-29-2020, 12:02 AM   #1
Chvy2NV
Cutting floor for hi hump tunnel ?
im going to be cutting my floor soon. looking for any pointers as to what to expect.. what tool did you use to cut ?
Chvy2NV is offline   Reply With Quote
Old 05-29-2020, 12:14 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Cutting floor for hi hump tunnel ?
A cutting disc such as a Lennox metalmax is a much better choice than the abrasive discs.....
Or use a sawzall or body saw...depends on what tools you have..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-29-2020, 04:33 PM   #3
LS short box
I did mine with a plasma cutter. Laid the high hump down. Traced around it then cut about 3/4"-1" inside the line. Cleaned up the cut with an angle grinder.
LS short box is offline   Reply With Quote
Old 05-29-2020, 09:56 PM   #4
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
A plasma cutter would be the cats meow, but I can't afford one. I used a cutting disc on an angle grinder. I also used a smaller disc on my die grinder in some spots. I would go for it and then just clean up the edges with a grinder.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 05-30-2020, 05:20 PM   #5
LS short box
Yeah the plasma is great. If you want nice radius corners just use a hole saw 1" diameter? in each corner and connect the dots with a sabre saw.
Old 06-03-2020, 12:09 PM   #6
First c10
First c10's Avatar
I placed my high hump on and drilled the holes in the floor then welded 3/8" flange nuts on the cab before I cut the hole. I cut the hole with a die grinder/cutoff wheel. It was pretty simple but I did have my cab on a rotisserie...
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 06-03-2020, 02:29 PM   #7
tinydb84
tinydb84's Avatar
Make sure there isn't anything under where you are cutting!
I used a combo of a cut off disc and an air body saw from harbor freight.
David
Instagram: myfabguy
Old 06-03-2020, 10:31 PM   #8
derotoreut
derotoreut's Avatar
Here's what I did to my 71 swb low hump. A bit unorthodox, but I wanted to assure no interference for my build. I was going to use a high hump, but still had some issues, so I made the change to fabricate a custom hump.
~ Dan
Old 06-03-2020, 11:34 PM   #9
Chvy2NV
cool
Old 06-04-2020, 01:49 PM   #10
tinydb84
tinydb84's Avatar
I had to do something similar due to my 4l80e swap and Z. Isnt the prettiest but everything fits now.
David
Instagram: myfabguy
