Air Intake Routing
Few questions - dont want to spend $70 on parts to not fit ....
Q1) The throttle body intake is 4". The Mass Air Flow Sensor is like 3.625" (pic below) ![]() So that would mean I need a 4" silocne bend..... a 4" pipe ..... then an adapter from 4" to 3.6" on one side of the MAF and a a 4" to 3.5" (intake filter) adapter on other side of MAF.
FAKKY 57 PANEL BUILD |
Re: Air Intake Routing
Q2)
Routing. ![]() The ideal spot is really on the drivers side fender - but thats where I have the PCM mounted. I could move it - but obviously cant move far. Was thinking if I routed it over the radiator hose sort of like one of these ..... Thoughts ?
Post Whore
![]() ![]() Join Date: May 2015
I used a spectre reducing coupling from throttle to maf..then the maf..then a spectre 90..then a Ebay alum tube with spectre filter at the end...had no issues and lots of miles..
Thanks.
Did you go with MAF or Speed Density tune ? https://ls1tech.com/forums/conversio...-location.html I dont think I can route quite like yours due to AC. Theres' 5" total between back of electric fan and accessory drive belt ...... with a 4" pipe .... kinda tight.
Post Whore
I've got a maf...and this could have just as easily went to the drivers side..
I put mine there be ause that's where the air flow thru the radiator support was.. .I was mainly showing how mines connected
#6 | |
Ended up buying a generic kit (as was cheaper tha sourcing individually) and I'll modify to fit as required.
I just bought this guy: https://www.ebay.com/itm/4-Cold-Air-...72.m2749.l2649
Routes over the hose to the passenger side, where the battery was originally. I'm interested to see how well it will fit over there. For the price I figured it was worth a gamble. |
#8 | |
Im going to try and route around the alternator side ..... might have to buy some other parts to make work ........ but a filter alone was $30. So figured heck.
Post Whore
Dang...that's cheap enough...I think I've got a little around a 100bucks in mine buying it in pieces
#10 | |
Pic of my routing. I had to buy an elbow with one leg long enough to clear the alternator. I like that the filter helps to hide the pcm/wires a bit. Sorry for the upside down pic, iPhone pics seem to do that.
![]() Join Date: Jun 2019
Best set up I have seen so far, is this one (stolen off another forum).
#13 | |
I didnt really think much on keeping engine bay tidy when I did everything. 1st time build. I think if I do again ...... Id relocate the battery to alongside the frame and hide the AC lines and wiring harness behind the fender. The powersteering lines for the hydroboost are hard to hide though.
#14 |
Heres what I ended up with.
To get the configuration of the abvove pics Id have to spend another $40 in adapters .... and cut the tube way down .... just probably not worth it. Kit is ok for the $$........ dont love it dont hate it. The filter is better quality than I thought but the adpaters are pretty cheap as expected. ![]()
#15 | |
#16 | |
#17 |
The best source of couplers and reducers I've found is siliconhoses.com
I routed my intake down the side of radiator - it sits vertically in the engine compartment with the end of the K&N filter fitting in a bracket so it is supported at both ends Here it is out of the truck |
#18 |
dang thats intersting ...... so basically straight down between the alternator and the radiator? towards front axle/rack ?
#19 |
Pretty much. There's a 'cup' mounted on the radiator support that holds the end of the filter and keeps the intake in place.
FWIW I had a new toy a couple of years ago that was a thermocouple temperature probe. I put the TC in various locations in the engine bay and didn't see much temperature variation as I drove around. The filter hides behind the fan shroud and is about even with the crank pulley on the engine. I doubt this truck will ever see rain, much less water that'd be high enough to get sucked in the filter, but I suppose it is a possibility. Before I painted it........... |
